4x6 photo paper jammed. cannot see paper from front or back.
SOURCE: Paper jam error light on kodak esp 5
NOTE: The printer will reset and eject the paper. If the paper does not eject, try to remove it manually.
SOURCE: ESP 7 paper jam error
I had the same problem, but after pressing the OK button when the paper jam came up again I pressed the CANCEL button and was able to print my document. See if that works for you too.
SOURCE: kodak printer esp.3 ...paper jammed
u should only use kodak inkjet papers with size plain paper, coated paper, photo paper, iron-on, transparency film, label media, greeting cards, 20 to 24 lb. plain paper. open back access door of printer by pulling out the latch on back of printer. remove paper-jam from the rollers. u can find manual for ur printer onwww.kodak.com/go/manuals.
SOURCE: Paper Jam HP 1350 All-In-One
The back of the HP psc 1350 DOES open! I got a 4x6 photo paper stuck too. After finding no help in the HP software manual, I accidently noticed that if you look closely at the back that grey area that looks like it should come off does! If you look closely you will see an arrow to the left of the gray panel. You can push right and pull toward you at the same time and the panel comes off where you can easily take out the stuck photo paper.
SOURCE: got a paper jam how do I take off the back to fix
Log onto www.kodak.com/go/itg and follow the online steps to either resolve the issue or tell you to contact Kodak for replacement.
Testimonial: "Was helpfull"
