As per you, you do get a display. It is a good sign. Press the menu button on your remote control, while the TV is switched ON, and go to its menu option; which displays the "System". There select the system to "Auto". If the system is not configured right, the picture will be not there. Making it 'Auto'; the set itself will adjust for the incoming signal type to it. If you're not fully aware about it, refer its user manual or contact any technician.
SOURCE: Panasonic 42 inch television
HEY !!
ITS A CIRCUIT BOARD PROBLEM ... IC MAY HAVE BLOWN OFF ...
SOURCE: ilo 42 inch Plasma TV
I have a Ilo 42 inch Plasma TV and it just stop playing, the power light comes on but the screen don't light up at all
SOURCE: tuning problem
The tuner is bad. Could also be the video process, since the hi-def is decoded there
SOURCE: How do I tell if my tv is analog
Hi Dru,
Good news, your 42 inch Phillips has a built in digital tuner, all you need is an antenna.
Please post the model of your other Tv and I will check on the tuner type.
I have provided a link to a site that has good info on antenna types and the channels you will be able to recieve.
http://www.antennaweb.org/aw/welcome.aspx
Let me know if this was the information you requested and please rate this solution.Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
SOURCE: Sound proplem
its the audio amp, its fried and needs to be replaced. match the numbers up and purchase/replace boards, this will solve your problem.
