Question about Canon NP 7130 Black and White Copier
How can i fix blank paper printing in canon np 7161 copy machine?
Posted by liyu on
5 Related Answers
EngineerKhamis
  • 16 Answers
SOURCE: Canon NP 6218 B&W Copier
try also to change or to service the corona units both the upper corona in the drum unit and the the transfer corona assembly unit down the drum. ok try your best.
Posted on Oct 02, 2008
Anonymous
SOURCE: canon np 7130
tengo problemas con mi fotocopiadora ella me imprime con una mancah negra por favor si me pueden colaborar.
mi corro es
[email protected]
gracias
Posted on Oct 30, 2008
Everett Lin
  • 990 Answers
SOURCE: Poor copy quality - lines on paper
Hello sir; The problem is caused by drum cleaning blade, you need to replace drum cartridge or drum blade if you can.
Posted on Jan 24, 2009
SOURCE: My canon MP40 will not scan/copy
This is because you have NOT installed the actual Drivers for the scanner and the Scan Manager. Driver link below. Ensure you get entire package A:SO get the user manual, it shows you what to do.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=15603
Posted on May 14, 2010
Anonymous
SOURCE: canon np 7130 copier turns on but cant copy. The
Canon NP 7130 F copier\r\nCopies are dark in some areas and light in other areas.
We no longer have a service agreement on this machine.
I cleaned the feeding roller in the ADF, new toner in machine, cleaned glass, recalibrated the exposure dial but it is still printing light in some areas and dark in others.
Thank you
Posted on Dec 17, 2010
CANON NP 7161 HOW TO QUALITY PRINT
Hi. Please be more specific and explain what you need so we can help you out , copies are blurred, darken or whiter?
Jan 30, 2018 | Canon Office Equipment & Supplies
I have a Canon NP 7130F which prints out only blank paper
check cartridge setting how-
check all spring on correct place
check ITR spring touch point
check printer to cartridge touch point
Apr 01, 2014 | Canon NP 7130 Black and White Copier
Canon 7161 error 805
• The exhaust fan (FM2, FM4) is faulty.or
• The DC controller PCB is faulty.
See Chapter 10 page 101 of the service manual You can download the service manual for the Canon NP 7161 from here See chapter 10 page 101
http://monitor.espec.ws/files/np7161_sm_123.pdf
Dec 29, 2013 | Office Equipment & Supplies
Canon np 7161 E004 error
Ok let me help u on fixing your problem.
mostly this error is in fusing unit and may be due to power disturbance.
first press * (star) then 2 & 8 together again *(star) if succesfully u presed 2&8 together and then *(star) the number 1 (one) will appear in the box [ 1 ] then press 4 then A (automatic exposure) then 412 and finally finnish by pressing the start button/print button the machine will go OFF turn it ON it is now ok. if not start again follow the sequency untill to the step of pressing the start button insted of it press A.
try your best, kibokoyao waiting for your vote.
Apr 26, 2012 | Office Equipment & Supplies
On canon iR 1020, i cannot print and make a copy
Do you mean that you have blank copies/prints, or that there is some message on display, or just blinkig red led...?
If yyou have blank copies the problem is in laser shutter.
If you have error message send detailed description.
May 21, 2010 | Canon NP 6035 Copier
A canon np 7161 with an e002 error code. It is my
ok let me help u on fixing your problem.
Apr 04, 2009 | Sharp AR-5316 Advanced Digital Imager...
Canon np 7161 simulation
hi help me with this formula to reset canon 7161 e0003 is *2&8 at a go, then * then A then 412 is this the correct way. ?????
Jan 08, 2009 | Sharp AR-5316 Advanced Digital Imager...
Key boadrd problem in canon np 7161
If You trust me ... then do it i had the same problem after too much hard work i found the LEDs was causing the problems just trust me and replace all the LEDs on the panel card ....
and remember me in ur prayers thanks and regards
contact me for further
[email protected]
country Pakistan
Muhammad Ali
Sep 15, 2008 | Office Equipment & Supplies
Canon NP 7130 Black and White Copier Logo
158 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
