U have to turn machine off and back on it goes away and than comes back
SOURCE: Unable to print envelopes on Xerox WorkCentre Pro 123
Some thoughts.
Envelopes won't print from bypass tray.
Cause:
Extended tray is not set up properly for envelopes.
Solution:
Fixed! Did not fix.
Enter tools "Login" 1,1,1,1,1
Touch buttons with the following names in that order:
System Settings
System Settings
Common Settings
Other Settings
Scroll down to "Extended Tray" Next to "Extended Tray" it may say "Inverter" if it does go to change settings then change it to "Offset Stacking"
Close out tools.
SOURCE: Xerox Workcentre Pro 123 error code 016-719
this is not a mechanical error but a software error.
It either doesn't recognise the format or program
as for the driver don't thinkit's the problem the HP can use PCL6
SOURCE: Open heat error
One of 2 things is happening, Either the Heating element is going bad, or more likely the thermistor that monitors the temperature of the fuser is intermittent. You will most likely need to replace the fuser to resolve the issue. That machine has a one year on site warranty. If its less than a year old Xerox will fix it for you free of charge.
SOURCE: I have Xerox workcentre pro
That is a software related error, You most likely need to reload the firmware, or replace the hard drive.
You can try disconnecting all the document feed and scanner cables then reseating them. Other than that, your looking at a software issue.
Go to Xerox.com. Click on the Support and driver section.
Type in 123 in the search box. Then when it comes up, select Drivers and Downloads, then on that site you can click on Documentation and download the User and Admin Guides. That way you can have that info at your fingertip.
The default code is 1111, or 11111. 4 or 5 ones.
