The glass oven door has brown stains...how can i clean inside the oven glass door
At the bottom of the glass door you will find an opening (usually two). Attach a glass cleaning wipe, or cloth sprayed with vinegar or glass cleaner to a bent wire hanger. Be sure the cloth is secured with zip ties or rubber bands. Then put the hanger with the wet cloth up thru the holes (vents) at bottom of oven door and clean away. An appliance repairman told me the door had to come apart, etc and an appliance repair person absolutely should do this. But I did my oven glass for free and it's great!
Taking the door off the oven and lay door on a soft surface so as to prevent scratching ,taking the door apart ( Carefully ), allow for a large work space, lay out your screws, the glass you are trying to reach is an inner glass, so obviously self clean is not going to help. Good luck!
SOURCE: Broken inside glass of oven door
Most units use Torx screws to hold the door together from the inside. Open the door, use tape to restrain the inside of the door or get help. Remove the 4 screws and the then remove the panel. Should be easy from there.
SOURCE: Cleaning better than self-cleaning
What you have read is correct, the catalytic lining can be damaged by corrosive sprays. It should be safe to use 'Easy Off ' on glass though.
The standard Auto clean cycle is the best method of cleaning that i know of.
SOURCE: Cracked see through glass -Frigidaire Gas Self Cleaning Wall Oven
Hi, You can replace the glass piece. You will need the whole model # when you call for the part.
Good luck. Please let me know if I can assist you further.
Thanks
Vic
SOURCE: GE 1978 Slef Cleaning oven JKP26002wh 3 Layers of
You will have to take the door apart to get to the glass that needs to be cleaned out. I would not recommend doing a self clean on an oven that is that old.
Thank you for your post, friend!
From my understanding after you used the self-clean feature on your Frigidaire range you now have brown and white streaks on the indoor glass. Typically streaks can be removed by cleaning the interior glass. Normally it is recommended to have a professional clean the inside glass but a consumer can do it as well. Use caution when following the steps some pieces can have sharp edges. You will need to have a Phillips head screwdriver or small quad bit driver.
A. Refer to owners guide for instructions on how to remove oven door.
B. With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner.
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
Hopefully this is helpful. -Matt
Below are instructions on how to take your oven door apart to
remove any stains that may be caught down in the door vents.
Tools needed: good Phillips head screwdriver or small quad bit
driver.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
hinges.
edge of table
assembly.
lining facing up.
item
H.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
