Xerox WorkCentre 7665 Copier Logo
A
Anonymous Posted on Oct 02, 2014
How do I dismantle the base unit from the xerox workcenter 7655
The base needs to be removed so we can carry the machine how can we do this
Robert A. Watson
Level 3:
  • Master 774 Answers
  • Posted on Apr 03, 2015
Robert A. Watson
Master
Level 3:
Answers
774
Questions
0
Helped
302859
Points
2079
Detailed manuals for both operation and installation are available for Xerox units. Go to their site and download both of them for specific instructions. Please remember to install the unit away from sources of heat , allow space around it for cooling, and do not use an extension cord!
Dave Smith
Level 2:
Scholar:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Xerox Expert 142 Answers
  • Posted on Apr 02, 2015
 Dave Smith
Xerox Expert
Level 2:
Scholar:
Cheetah:
Answers
142
Questions
Helped
67445
Points
230
Look inside the left hand side door ( stacker unit)
the unit is locked onto the side panel with a sliding bracket. Look for a thumb metal bracket and push it to release the stacker unit.
normally these units aspire very reliable. Undo the unit and the interconnections then slide apart.
Good Luck.
5 Related Answers
Anonymous
  • 2072 Answers
  • Posted on Oct 17, 2008
SOURCE: Xerox Workcenter Pro 657 Memory Error
With a 657, most likely the main board has failed. It is not uncommon at all, That is a general problem with that model.
What you can try is, looking from the front of the machine, the main board is located on the back right side. removing 2 screws and releasing the levers will allow you to slide the processor board out of the machine. You can try just reseating,,,, removing and shoving the board back into the machine, and seeing if that helps.
Most likely, either the board has failed, or the memory battery had exceeded its life and the memory is not working.
Wish I had a more positive answer for you, but the 657 is getting older, and those lithium batteries are failing. I have to add though, that those processor boards, have failed pretty frequently over the years.
What you can do is go onto Google and look up "the parts drop" ,,, call them and ask for Britt, and see what he has as far as that producut is concerned. That machine is actually made byn Toshiba, you may be be able to find either a Xerox, or Toshiba repair dealer in your area that has that board and will fix it reasonably. If you find a Toshiba dealer other than a Xerox dealer. Tell them it is the same machine as a Toshiba E-120, they are exatly the same.
Anonymous
  • 2072 Answers
  • Posted on May 15, 2009
SOURCE: Dismantling Printer to be able to carry down stairs.
Yeah. On the back of the document feeder there is one white molex connector. Unscrew the 2 thumb screws and lift up and puch back gently while lifting the feeder. The hinges will release pretty easily, then set it aside.
Also the paper tray, pull it forward, then up and out.
Removing those will make it much easier to move.
If you have a third tray, it should just be sitting on it. If the did install the clips, take the back cover off and remove the screws and plate. But most M20s with a lower tray, they just sit on the machine.
If it is conncected to a stand, just remove the back screws and lift it off the stand.
Anonymous
  • 24 Answers
  • Posted on Oct 25, 2009
SOURCE: xerox workcenter 7665 communication problem
This was an issue with earlier models and is usually attributed to the "USB" connector on the bottom of the control panel not being attched securely. Note: although the connector is USB, it is NOT hot swappable and will crash the machine if unplugged while the power is on.
Power off the machine. Ensure the cable is securely attached and restart the 7665. Make sure when you turn it off that it is completely off before restarting or you could corrupt the system software.
Anonymous
  • 21 Answers
  • Posted on Dec 02, 2009
SOURCE: xerox workcenter tray 1 will A3 size ,if printuing
igual tienes un papel en el fondo q oprime los pulsadores detectores del tamaño del papel
Anonymous
  • 1110 Answers
  • Posted on Dec 22, 2010
SOURCE: I have a xerox workcenter XD102 with a J1 error.
J1 code on the XD100 series means that your toner cartridge is empty. You will need to order in a new one or have your existing cartridge refilled. Refills run about $60.00 and new ones are in the $100 to $125 range.
Precisionroller.com has a very good remanufactured unit for $46.00
http://www.precisionroller.com/search.php?q=xd100+toner
Good Luck and Thank You for using Fixya.
WheatlandServices
What is the procedure for dismantling a Xerox 5665 developer unit which is faulty?
That unit is a consumable, you're not supposed to dismantle it.
Xerox WC 7655 host to host usb failure. comunnication error 7655
Try changin the usb connector of the cable that goes from the screen to the rear left of the machine. There are 4 connectors there.
Xerox 7655 can it borderless print
No it's fisically not possible. There will always be an edge.
Try to print on a bigger piece of paper and cut it.
8helpful
4answers
FAULT CODE 124-373 ON WORKCENTER 5225 WILL NOT CLEAR
Xerox 5225 keeps showing error 124-373 and cant one to enter into set-up or status mode.How to correct this error?.I have jobs to copy for urgent meeting soon.your email is needed
16helpful
2answers
Our xerox workcenter 7235 fault code 024-360 and copy service is disabled
024 360 An error has been detected by the Controller during communications with the Printer. User intervention is required to Power Off/Power On the machine, Field Service is required if the problem persists. Printing is disabled.
http://www.support.xerox.com/go/results.asp?Xtype=docs&prodID=WC7228_WC7235_WC7245&Xlang=en_IN&Xcntry=IND
You will have to either get this printer repaired or replace it.
13helpful
2answers
Xerox PE220 workcenter shows LSU Error message.
XEROX WORKCENTER PE220 , ITS SHOWING LSU ERROR . ITS NOT PRINTING OR COPYING ANYTHING . PLEASE GIVE SOLUTION
1helpful
Xerox PE 120i workcenter. Error says
you need to remove your paper tray.take your toner carriage out ,yurn the mc and assess
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
