Blinking clean light flashes 7 times pause and 1 flash and repeats
SOURCE: clean light flashes
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all
the lights will turn on briefly and the machine will start a diagnostic
cycle. You can press cancel or let the diagnostic cyle finish (1-2
minutes).
You should now be able to run the dishwasher as normal.
SOURCE: We have a kitchenaid dishwasher model#kud102irbl
If the clean light flashes 7 times, pauses, then repeats...
When
the dishwasher doesn't sense a water temperature increase, it will
stop working and lock the functions (clean light flashes 7 times, all
buttons are non responsive). It does this as a safety in case the
element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all
minutes).
If
the issue returns, you could have a problem with the heating circuit
(ie. element, thermostat or wiring). It rarely happens but it could
also be the door switch not engaging properly when the door is closed
(slightly bend the door latch down making sure it doesn't hit the door
when you close it).
SOURCE: kenmore 665 17033400 Elite dishwasher clean light
That signals an issue with a faulty heater &/or heater drive circuit.
(that info comes from their troubleshooting guide)
I ran into it this weekend and discovered that the heater coil in the bottom of the washer was broken.
SOURCE: Dishwasher is locked out. Clean light flashes 7
Hi
Thanks
for using FixYa. If the clean light flashes 7 times, pauses, and then repeats. When
the dishwasher doesn't sense a water temperature increase, it stops working and
locks the functions (clean light flashes 7 times, all buttons are non responsive).
It does this as a safety in case the element is broken and feeding electrical
-high temp wash
-heated
dry
-high
temp wash
-heated
dry
All the lights will turn on briefly and the machine will start a diagnostic
cycle. You can press cancel or let the diagnostic cycle finish (1-2
minutes). You should now be able to run the dishwasher as normal. If the
issue returns, you could have a problem with the heating circuit (i.e. element,
thermostat or wiring). It rarely happens but it could also be the door
switch not engaging properly when the door is closed (slightly bend the door
latch down making sure it doesn't hit the door when you close it). Please
do rate the solution if the issue is resolved or post a comment for further
assistance.
Thanks
Rylee
SOURCE: my dishwasher isn't working. The clean button
Hi
Thanks
for using FixYa. If the clean light flashes 7 times, pauses, and then repeats this occurs when the dishwasher doesn't sense a water temperature increase, it stops working and
-high temp wash
-heated
dry
-high
temp wash
-heated
dry
Please
assistance.
Thanks
Rylee
