Televison & Video Logo
A
Anonymous Posted on Oct 02, 2014
What is the pin code for Aiwa HVFX5500 vcr
I NEED PIN CODE FOR MY Aiwa VCR HVFX5500
Mohamad Abdan
Level 2:
  • Expert 71 Answers
  • Posted on Oct 25, 2014
Mohamad Abdan
Expert
Level 2:
Answers
71
Questions
Helped
20747
Points
116
Hi ,
Try...
Power on,
Press both CH/UP key and REC/OTR key for more than 2 seconds,
OK will appear in the display panel.
or try
Press CH DOWN key on VCR while pressing the 7 key on remote and hold for more than 5 seconds.
The display should then show OK.
but First disable the child lock by pressing the "lock" button on the remote,
and only then press "Ch-" and "7".
5 Related Answers
Anonymous
  • 275 Answers
  • Posted on Mar 07, 2007
SOURCE: Aiwa HV-MX100 multiformat VCR won't power on...
Too little information to give any information / help / opinion. What actually happens? Does the Display come on properly? Do you hear any mechanical Noises? Like a motor whirring? Are you able to load a cassette into the machine? Does it get ejected automatically? As you say that the machine switches ON, I assume tyhat the Power supply cicuits are Ok, and this leaves us with the possibility that there is a mechanical problem.Is it that the machine was not used for a long operiod of months or years? If that is the case, in all probability the belts are damaged / broken / loose. I really need more info, please.
Anonymous
  • Posted on Sep 26, 2008
SOURCE: NO VCR MANUAL
I have no solution, but have the same problem: NO Manual for my /hv-BR 5000 BH VCR. Can anybody help?
A
Anonymous
  • Posted on Oct 25, 2008
SOURCE: orion vcr code
  1. what code do i use fpr orion vcr
Anonymous
  • 120 Answers
  • Posted on Jan 15, 2009
SOURCE: AIWA VCR model HV-MX1problem
with the unit unplugged take the case off and look on both sides of where the front of the tape would set, you will see two towers, one is a light and the other a receiver,check to see they are plugged in and not obstructed.Also there is a switch that the tape pushes when its all the way in which might be stuck,click it a couple times with your finger.This might help, there are other more complicated things which could cause this problem but mechanical problems are more likely.
Anonymous
  • Posted on Sep 26, 2009
SOURCE: Aiwa GX1100 VCR
When safe show on the screen, it actually means that the child lock feature is on.
All you have to do is press the child lock button again on the remote and it should flash "OFF" on the screen.
Hope you have the remote :)
1helpful
How do i unlock aiwa vcr hvfx5500
Most obey the code 1234 or 0000, possibly 12345 or 00000.
1helpful
2answers
I forgot my aiwa digital 40 lock password , & it lock rightnow what can i do ?
Hello
Just try this method to overcome the situation.
With TV turned ON simultaneously press "Volume Down" button on the front panel of the TV set and digit "7" button on the remote control to reset the pin code and customer ID. You have to reset the pin code and customer ID after this process. This must solve your Aiwa TV problem. OK.
Need to find code for Jumbo Universal Remote to use with Aiwa S2011 MTS television. Thanks for any help!
Hello
Aiwa TV is not lited on Jumbo Universal Remote codes. Anyway try out with these codes. Sometimes may help you.
Three digit codes for Aiwa TV with universal remote are:
195/ 196
Four digit codes for Aiwa TV with universal remote are:
0195 0196 0227 0269
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
NOTE: Switch OFF and switch ON your TV with its FRONT PANEL POWER ON-OFF SWITCH each time before trying an other code.
OK
Need to reset pin on VX-FT21 aiwa tv/vcr combo how do you do this???
how do i change brightness/colour/contrast if i dont have the romote control for the aiwa VX-FT 21. video/TV combo. My screen has got really dark and I cannot find a manual pannel to change it form on the TV - me and all my friends have looked everywhere but there - if someone could email me at [email protected] that would be great. Thank you
I lost my original remote control for my AIWA combination TV/ VCR. VX-S135 ? I bought a universal remote control but there was no code listed for an AIWA TV. Just a VCR. I need to know the code to the TV...
what's the name/make and model of the remote?
Without me knowing the type of universal remote, there is no way I can get the right code for your TV.
I look forward to your reply.
Bye for now.
1helpful
Lost manual
how do i unlock the pin code? aiwa fx7500k
7helpful
Code
PIN CODE RESET - UNPLUG SET FOR 2HOURS, VOL TO MIN. PRESS VOL- ON SET & "7" ON R/C FOR 5 SECS WHEN "PROTECTED"
Aiwa VX-FT21
select P+endP-thogheder end power up of swche stby 5,6 sec end relaes after this select stby of remont control
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
