Question about Fisher Paykel : DD24DCTX6 Semi-Integrated Double DishDrawer - Sta
If you don"t mind proceed with this extraordinary work and I anticipate a greater amount of your magnificent blog entries. mobiele airco
Posted on Sep 11, 2021
SOURCE: Fisher & Paykel Dishwasher leaked
From what you describe, drain water from the top drawer is getting into the bottom drawer or waste water from the disposer is backing up into the bottom drawer.
1. Each drawer has its own drain hose. Each hose should terminate at the drain point with a 'Y' adapter.
2. Inspect the drain point (under the sink where the drain pipes are) to make sure this 'Y' adapter is present. (you should see two drain hoses from the DW). If not present, then the DW drain lines are not installed properly. (Someone took a shortcut and installed the 'Y' adapter behind the DW)
3. If terminated properly, make sure the drain hoses extend upward as they leave the drain point.
It is important the drain lines are connected properly to ensure proper drainage from the DW. Consult the installation manual for complete details.
Posted on Jun 08, 2008
SOURCE: dishwasher error
The error was a flood fault, water was not draining from either of the drawere, I removed the bottom drawer, dried drip pan and used hairdryer to dry fault sensor, the dishwasher then reset itself and works fine.
Posted on Jan 01, 2009
SOURCE: fisher n paykel nemo dishwasher won't go. Sounds
Check to see that the outlet pump (underneath) isn,t stuck eg sumething stopping the pump from turning.Also check that the outlet is clear where it connects to the sink outlet.Hope this helps.
Posted on Dec 13, 2009
SOURCE: Hi. Our DS603I dishwasher starts
Dishwasher Repair Guide: How To Fix a Dishwasher - ACME HOW TO.com
http://www.fisherpaykelparts.net/ecart/item.php?item_id=244
sounds to me as though you have a main controller or indeed some sensor has failed, with this symptom is it a bit hard to exactly pin it down.. The best thing to do if you wish to DIY, is obtain a service and repair manual, and work through the troubleshooting steps to isolate your issue with a view to repair, also the SM has parts numbers too.
The below may NOT apply to you... however it has helped many many times...so if you think it is worth a try... give it a go.. nothing to loose?
so your dishwasher won't do anything... it justs sits there and "Hums" you can't make it respond to any controls, and the ONLY way to Stop it. is to unplug the unit, replugging back in it simply "Hums" again and will do nothing.
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle.This should NOT be done. You should NEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
Now, the FIX. Take the Dishwasher, out, and tip over on it's side, tip to about a 45' angle. Water will come out from underneath, this is from a small "Overflow" reservoir. this reservoir has an "Anti-Flood" switch. The removing of this water will "Reset" this Switch, and allow the dishwasher to work again.
So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method.
Posted on Feb 13, 2011
SOURCE: i have a Fisher and Paykel Dish Drawer dishwasher.
it is likely the lid seal is stuck. You will have to get the drawer out and check the underside of the cabinet at the top.
The lid seal is a rubber lining which is actuated by a pair of motors. If the motors are faulty or the power is to the motors is lost, then the seal will not go up to let the drawer sit properly.;
Posted on Mar 20, 2011
