SOURCE: Squished Rows in Office 2003
Follow the next steps:
1.- Choose in the menu File.
2.- After Choose the option Sent to.
3.- After Choose the option recipient (attach data).
SOURCE: 1. calculation for excel spreadsheet macro for
Hello this is Baris,
First off all when you say hypotinuse I think it is a 90 Degree triangle. Total of the angles off a triangle is 180 degree. So it is a simple algebra question.
Hypotinuse is 90
Right angle is R
Left angle is L
Total is 180
Equation is 90+ R +L = 180
We are looking for R, so lets arrange our equation.
R= 180 - 90 - L
R= 90 - L
This is our formula for excel
Lets put it in the excel
Type in A1 "hypotinuse "
Type in A2 "Left Angle"
Type in A3 "Right Angle"
Type in B1 90
Type in B2 "whatever the value given for the left angle"
Type in B3 =90-B2
As soon as you change the value in the cell B2, B3 will change by itself. Hope this helps :)
SOURCE: When I try to merge my excel document with 250
Hi deloisr
It looks like you have chosen the wrong data file. Probably an earlier version of your data still present in some folder.
Check these
Do you have column headings for every column?
Make sure which folder contain the file? What exactly is the name?
When you are in the Microsoft word, make sure you select the correct data file for your mail merge. If you have selected the correct data file, when you attempt to insert the merge fields, there is no way, it give wrong field names.
The only reason you get the erong field names is because you have the wrong excel file for your data. Fix this problem first, then the rest will sort themselves out.
Have a good day.
luciana44
Testimonial: "At first I dismissed this assessment but when I checked my document I found the advice was correct, my problem is solved. Thank you. "
Start off by doing one of the following: Select the range of cells that you want to make into a table within your worksheet then proceed to Step 2 OR Start immediately with Step 2.
Click on the "Insert" tab at the top of the document.
Find the "Tables" group, then click on "Table." The "Create Table" dialog box will appear.
Type in a range for your table if you did not select a range in Step 1. If you did already select a range then that range will automatically appear in the dialog box.
Check the "My Table Has Headers" box if the data set you selected already contains the headers you want to use. If you don't check this box, the table will display default header names, which you can then go in and change.
Hit the "OK" button at the bottom of the Create Table dialog box to create your table.
