Theres alot of things you can do if you are experienced
But mainly to to the menu and scroll through til you find the reset button and reset your camera
I recommend to bring to any local repair shop or Nikon USA. Local repair shop would charge cheaper, because the they only will change the defective motor instead of ass\'y. Price would be very like $70 to $215.
SOURCE: nikon d40
Take the lens off and continue pressing the shutter untill it doesn't react anymore, you should then have a normal menu without the error message.Put your lens on and you're all sorted.Cheaper and less hassle than sending it to Nikon.
olly
SOURCE: Initialization Error/Press Shutter Release Again
Sounds like some software error.
Try updating the firmware for your Nikon D40 camera.
Here it is:
http://support.nikontech.com/cgi-bin/nikonusa.cfg/php/enduser/std_adp.php?p_faqid=14167&p_created=1169491133&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PWRmbHQmcF9ncmlkc29ydD0zOjImcF9yb3dfY250PTEwODUmcF9wcm9kcz0mcF9jYXRzPSZwX3B2PSZwX2N2PSZwX3NlYXJjaF90eXBlPWFuc3dlcnMuc2VhcmNoX25sJnBfcGFnZT0x&p_li=&p_topview=1
SOURCE: Error. Press shuter release button again
I was taking pictures, then when I pressed the shutter release button, it took a long time. Then the error message came up. I tried pressing the shutter release button again, nothing happens. Still the error message. Please help me
SOURCE: Nikon d40x shutter stuck
The manual (pg 112) simply, and unfortunately, states this message "Press shutter release button again. If error persists, consult with Nikon-authorized service representative".
Some questions that might help: have you had the camera in some extreme conditions, damp, sand, etc. Clean the shutter button really well. Maybe use a small air blower and clean in the shutter release creases.
In the end, if the error continues, it will need to be serviced.
SOURCE: faulty nikon d40
I had the same error message, the camera is less then a year old, however, I was taking up to 800 pictires every weekend of my kids soccer games, then a 6 month trip to the Pursian Gulf, that is when it started, I got back home, took it right in, and one year later after a few visits and calls trying to find out where my camera was, I finally got an answer back, they said I needed a new shutter which will cost $300, They said I should just by a new body for $400. What Nikon does is set that error message to pop up at about 35000 shutter releases, and you can't do a thing about it, once they hooked my camera up to thier system the said I had over 36000 shutter releases, where the average person takes 10000 a year and they want you to replace the body every 3 years....so before buying any camera, always check out how many shutter releases you can get when you buy a camera
Rob Smith
Victoria, BC
