Question about Hardware & Accessories
HOW TO RESET A KINGSHIELD IMMERSION HEATER TIMERundefined
WATER NOT HOTTING UP SUSPECT SOMEONE HAS MESSED WITH SETTINGS NEED INSTRUCTION MANUAL TO RESET TIMER
Gene Haynes
  • Hardware & A... Master
  • 5,391 Answers
Http://waterheatertimer.org/Woods-timers-and-manuals.html#PB
Identify timer among timer modules shown on link above
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Oct 03, 2014
5 Related Answers
Anonymous
  • 131 Answers
SOURCE: Where can i get a user guide/instruction leaflet
http://www.greenbrook.co.uk/pdf/T106-C.pdf
AndystUK
Posted on Aug 30, 2009
Anonymous
SOURCE: I bought a new house
Maim website:
http://www.taco-hvac.com
Main website Search for Taco 265-1 gives link to manuals:
http://www.taco-hvac.com/search.html?gsearch=Taco-265-1&action=results&cb_products=YES&cb_filelibrary=YES&cb_news=YES&search_type=all_terms
Direct link to pdf manual:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://www.taco-hvac.com/uploads/FileLibrary/102-067.pdf
Instructions show series of actions to set digital program
Press h key ...
Press m key...
Press Day key...
Press Prog. key to enter...
Posted on Sep 13, 2010
Anonymous
SOURCE: How can I get a instruction manual for this timer?
You posted under Stanley Timer Max pro, which is also sold as Westinghouse timer T00442.
See image to confirm this is your product:
http://waterheatertimer.org/images/Westinghouse-T00442-500.jpg
Manual for product shown above is on link below
http://waterheatertimer.org/pdf/51215_timer_EnFr.pdf
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Jan 23, 2011
Anonymous
SOURCE: My water heater needed to
Grundfos timer and pump operate by plugging into ordinary 120V outlet.
1) If outlet has power, then dial on timer should rotate.
If dial is not rotating, then check power to outlet.
2) If outlet has power, but timer is not rotating then timer has gone bad > if grundfos pump is working but timer is not working, you can buy cheap plug-in timer and use that as the timer.
3) If outlet has power and pump is not working, then manually rotate timer dial to see if pump will start.
If pump will not start, then you need a new grundfos.
There are no repair parts for these pumps, and nobody at Fixya has reported taking Grundfos apart and repairing it.
My Grundfos pump will not come apart.
4) Following link has links to Grundfos installation manual, website, product manuals, and contact.
http://waterheatertimer.org/Water-heater-recirculation-system.html#Grundfos
5) To set timer: Grundfos timer dial has movable pins that are used to set on-off times.
When pins are pushed out, timer turns pump ON.
6) Rotate timer dial clockwise until current time lines up with arrowhead located on inner dial.
Dial rotates as time passes, and pins move a lever that turns pump on-off.
For a price, expert speaks with you over phone while you work on Grundfos or any do-it-yourself project.
Posted on Feb 09, 2011
Anonymous
SOURCE: need to reset my ml121rt
1) Manuals appear on following two links:
http://malibulights.com/customer_service/owners_manuals.aspx
http://www.intermatic.com/products/professional%20lighting/light%20expressions/power%20packs.aspx
http://www.intermatic.com/~/media/files/intermatic/products/instructions/professional%20lighting/ml121rt%20trilingual.ashx
2) For more information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Posted on Mar 05, 2011
Need instructions for grasslin 16 amp immersion heater timer
https://fauroanofi.files.wordpress.com/2015/03/grasslin-immersion-heater-timer-manual.pdf
Apr 21, 2015 | Hardware & Accessories
I have just moved into my new apartment it as a newlec nle7 water heater with a timer, i can't get it to work, i need a user guide manual lisa
I think it is the same as the Horstmann Electronic 7 immersion heater timer. You can download it free from the Horstmann web site.
Dec 24, 2010 | Heating & Cooling
We have a Reliance 501 Electric Water Heater. We get only very hot water in bathtub in one bathroom but not the other bathroom. Could the problem be the water heater?
No, the problem is not in the water heater. It could be the plumbing pipes were installed incorrectly.
A common problem with hot water is also found in the settings of anti-scald and pressure balance tub and/shower valves. You may only need to reset the temperature control on each faucet. Every faucet brand has a slightly different adjusting system. Hopefully you can find the faucet's brand name, and then visit their website to find the owner's instruction manual for your model.
A cross connection in the water piping system is rare, but it does happen from time to time. It would allow cold water to mix with the hot. You would need a plumber or leak detection company to locate every water pipe connection in and/or under your home to confirm and correct the issue.
Sep 05, 2010 | RELIANCE ELECTRIC WATER HEATER
Low pressure from immersion heater to mixer taps on bath can i fit a pump on the pipe work leading to the bath
You need to have an higher head of water on the tank that feeds the cylinder that the immersion heater is fitted to. Put the tank on a framework say 3 foot above its present level.
Regards
Alan Hood
ami-man
UK
May 10, 2010 | Plumbing
I have recently had a Howden domestic immersion
I would not have both on at the same time . We never did .
Oct 30, 2017 | Water Heaters
Problem with hot water from Vokera Excell 80sp boiler
Hi - hope someone can help. I have a VOKERA EXCEL 80SP combi boiler and been without hot water/central heating for two days. The pilot light is on, the fan is on, but boiler not triggering once the hot water tap is turned on.
Hopefully someone come to look at it today but hoping for some advice. Anyone else had this problem?
Thank you.
Dec 21, 2009 | Water Heaters
Electric immersion heater keeps cutting out
Sounds to me like you have a bad thermostat. You should be able to give a model number to any local plumbing supply place and get one for replacement. make sure power is of the unit before replaceing.
Feb 02, 2009 | Carrier TSTATHCP Programmable Thermostat...
Hardware & Accessories Logo
295 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
