SOURCE: unclog yellow
Same problem yellow almost completely clogged, any tried a power clean from the printer control panel?
SOURCE: Epson Stylus Pro 9600 vs Agfa Sherpa44
The Agfa Sherpa is not manufactured by Epson. Both Epson and Agfa buy and retag their printers from Mutoh.
I do not know if the 44 is the same as Epson 7600 or 9600, but it should fit the same cartridges.
If the printer does not accept the cartridges, that means that there is something different in the software stored in the Epson cartridge chip.
In this case you will be only able to use only Agfa or Mutoh Falcon cartridges.
SOURCE: epson 9600 magenta won't print - have new cap assembly installed
The ink should come out of the cart. if not the cart is the problem at this point try anothere magenta if that does not shore it up then you need to then start looking at the print head where it goes it itself now the store you bought the ink from will give you a replacement no questions asked sometimes even if you dont got the reciept. Try those steps you be glad you did.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: I have a Epson 9600 pigment printer,I am using
It probably has to do with the chip embedded in your cartridges. This tells the printer what kind of ink you're using. Your cartridges could have the wrong chip.
SOURCE: Hi, On Epson stylus Pro 9600.
ORDER your printhead directly from here
http://www.alibaba.com/showroom/epson-print-head-9600.html
The
100005 is a maintenance required error! The maintenance needed is a
different printhead. Ensure that you purchase the printhead that comes
with a good return policy in case the error continues. NOTE: With
exchange of the printhead, this error normally goes away.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
