Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Replaced the interface board and only the hrs light is flashing.
Model# psc23sgna bs
Posted by Ash pate on
1 Related Answer
Robert Hirst
  • 833 Answers
SOURCE: ge profile arctica
It is unlikely that a power outage by itself will cause your problem. Recheck hour refrigerator thermostat. It should regulate to 38-42 degrees F. You can take an outdoor thermometer and put it into the fridge compartment, leave it for an hour or two and check. Adjust as necessary. If that doesn't fix it, we can proceed further.
Posted on Jan 24, 2008
Tv screen flashing like a strobe light
You can try to Reheat or Resolder the Inverter Board of your tv. Thanks if you tried and msg me if it does.
Jan 19, 2015 | RCA L40FHD41 40. in HDTV
Code 5y ce
Hello Marc Donmoyer - Could the error code be SY CE? If so, then the refrigerator has detected a communication error at power up. Contact a professional to move forward accurately to check the wiring between main control board and user interface. Depending on the diagnoses, either or will need replacing.
Dec 18, 2012 | Frigidaire FGHB2844L (27.8 cu. ft.) French...
My kitchen aid dishwasher will not start I replaced the interface control board thinking that was the obvious problem. When you go to set the dishwasher to start some of the settings don't always light up...
check all cables especially the ribbon cables from the user interface to the electronic control assembly as steam from dishwashings will create small amounts of corrosion and inhibit signals to and from these 2 components,unplug each,inspect,and reconnect,if this fails,then replace the electronic control assembly located behind the user interface you previously replaced
Mar 23, 2011 | KitchenAid Dishwashers
Have a model WD 55734 and the screen is completely black when turned on, and the tv makes a loud chirping or clicking sound that continues even when you turn the tv off. Lamp replacement??
Tv LED"LAMP"light flashes,projection lamp been inside the tv like 1 1/2 or 2 years?Used like 4 or 5 hrs daily?Yes,the tv projection is dead,should be replaced.The clicking noises,that mean the board call the Ballast board also dead,must be replacing too.The Ballast board only job it to ignite the tv projection lamp.
Feb 13, 2011 | Mitsubishi WD-57734 57" HDTV
Warm fridge cool freezer
Hi folks,
IS, the freezer so packed full with packages that they are covering the air vents in the freezer that must be open to share the circulation with the fridge?
Let me know!
If not keep calling the server and pay him only when he fixes it!
Sep 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Troubleshooting
8 flashes indicates a main processing IC on the video process board has failed You will need to have the BU board replaced.
Jul 27, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Ge profile arctica
Jan 23, 2008 | GE Profile PFS22 33" Artica French Door...
Tv will not come on
the problem for 7 blinks is an Interface board. Had mine fixed yesterday. Apparently there is a glitch in the interface board that sends signals to the television. Basically the glitch shorts out the board and the t.v wont turn on and you will see the power light blink 7 times pause then 7 more. They replaced the board with a new one and updated the software on the new interface board. It works like new and i couldn't be happier to be watching it again. Hope this helps everyone else out.
Dec 21, 2007 | Televison & Video
42" Plasma TV Problem
same frustrating symptoms on brand new 42inch here! tv just turns itself off sometimes without warning or if changing to certain channels. leaves red light flashing for a while then red light goes away. any attempts with remote gives flashing green liht on tv. manual power off and on restarts tv but auto off again. found while manual power on keep changing channel on remote till stable picture appears. then use remote to shut down tv - solid red light indicates standby mode. then use remote to turn on again... till next time it happens. but what is technical fault??
Aug 18, 2007 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Refrigerators Logo
75 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Mike McBirney
Level 1 Expert
gbob59
