Question about Brother HL-2040 Laser Printer
Why my brother HL-2040 printer is not giving licking sound on startup
When I am starting my brother HL-2040 printer, it does giving licking sound during startup and also not reading toner and paper etc
Posted by Muhammad Khaliq on
David Payne
    Top Expert:
  • Brother Master
  • 14,162 Answers
Brother International Customer Phone Number Shortest Wait Best Support
Phone Number
800-284-4329
Talk to a Human
Press 7 or Keep saying "Other"
  • Call Time
    Average Wait: 8 mins - 24 hours, 7 days
Posted on Dec 30, 2014
Wbix
    Master:
  • 364 Answers
A clicking sound when the rollers are rolling means something has got stuck in it. Maybe a bit of paper or card. It might be that the foil on the fuser has got ripped. You need to open all the hatches and pull out all the toner and trays and imager and anything that comes out easily. Inspect if for jammed material.
Posted on Oct 02, 2014
5 Related Answers
Anonymous
  • 21 Answers
SOURCE: Re: paper jam in brother laser printer hl 2040 : paper red ligh continue to flash
Try shutting the printer completely down & unplug power. then plug power back in and while holding down all buttons on the printer control panel, turn it back on. this should put it into a self diagnostic mode that prints out just about everything the printer can do, including a sample page. Also, be sure all rollers are clean & trays are completely closed before restarting. If the printer works when you do this, you should most liely check all settings in the software package (driver) or perhaps reinstall the drivers. If this is necessary, be sure to download the latest drivers from the Brother website.
Posted on Feb 11, 2008
Anonymous
SOURCE: BROTHER Hl 2040 PRINTER WON'T PRING
I got exactly the same problem and the "reset" didn't do anything. I fixed it by putting a piece of duck tape on magic eye on the cartridge.
Fallow those step to do the same thing as me:
  1. Open the front panel.
  2. Remove the toner and the drum
  3. Remove the toner FROM the drum
  4. On each side of the toner, there should be a little glass. Put the piece of duck tape on one of them. I put mine on the right side.
  5. Put everything back in.
  6. Turn on your printer if it's not already.
  7. Now, the low toner light should be gone and the green light should be on.
Now, you can really empty your cartridge.
Posted on Nov 06, 2008
Anonymous
  • 4 Answers
SOURCE: brother hl 2040 laser printer
On the brother printers, the fuser is often attached to the toner (they come out as one piece). If you look at the old toner, you will probably notice that it is longer than the new one. The extra piece that makes is longer needs to be taken off of the old toner and attached to the new one.
Posted on Nov 12, 2008
Anonymous
  • 54 Answers
SOURCE: won't print. blinking red paper light flashing
This usually means your printer is out of paper or there is a paper jam somewhere.
Posted on Mar 25, 2009
Anonymous
SOURCE: BROTHER HL-2040 PRINTER WON'T PRINT
Remove the Toner Drum unit and look for a little blue tab. Slide it back and forth a couple of times to clean a corona wire and see if that helps.
Posted on Jul 14, 2009
My brother HL-2040 Printer is not giving licking sound during startup as well as it also not reading the toner/paper why?
Not sure what you mean by "licking sound during startup"
As for the Toner not reading most often this is caused by the toner cartridge being empty. Try replacing your toner cartridge. If you have recently changed the cartridge it may not have triggered the Toner Reset microswitch. The reset gears on the side of the cartridge will need to be changed back to the ready position. If it is an OEM cartridge then take it back to the place you bought it from and they can replace it and send it back to brother. If it is a remanufactured cartridge then take it back to where you got it from and they can reposition the gears for you.
Not reading the paper can be because there is no paper in the machine or the paper feed system is worn and needs to be replaced.
Oct 02, 2014 | Brother HL-2040 Laser Printer
I want to download brother hl-2040 laser printer driver
You can download the Brother printer drivers from their support WEB site. Please click on this link and select your model printer to download : - http://www.brother.com.au/ProductsSolutions.aspx
Feb 12, 2013 | Brother HL-2040 Laser Printer
Losts installation cd for my Brother HL-2040 printer
go to microsoft and down load drivers typ your type of printer inand it will give u the drivers u need
May 15, 2010 | Brother HL-2040 Laser Printer
I need to download the drivers for my Brother HL-2040
There is no Mac driver available for this printer. But you can follow the steps to install your printer for Mac
http://pub.brother.com/pub/com/pdf/macosx/mac105_driver_usb.pdf
Sep 09, 2009 | Brother HL-2040 Laser Printer
Resetting the counter for Brother HL 2040
wecan reset brother cartage 2ways. when we are filling at that time we can adjust white ringe of cartage. otherway after reffiling . and when we put cartage in side the printer. we should push white and black point and start the printer .then it wi be reset.(it is tech. private methode)
Jun 11, 2009 | Brother HL-2040 Laser Printer
HL-2040 printer won't function
You can't hook up two HL 2040 with 1PC. It will make your PC crazy and don't know which printer should go for printer.
You must remove 1 HL2040. After that you should be fine.
Dec 04, 2008 | Brother HL-2040 Laser Printer
Lost Installation CD for my Brother HL-2040 printer
Where Can I download installation software for Brother HL-2040 printer
Sep 13, 2008 | Brother HL-2040 Laser Printer
I put a new toner cartridge in and the toner light remains on and will not print.
Actully i have hl-2040 brother printer
the problem is no lights are on
ready light not started plz give
me suggession my mail id is [email protected]
Jan 08, 2008 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
107 people viewed this question
Norman  J Weimar Jr
Norman J Weimar Jr
k24674
