Serial Number: > 742709357220 > 3CAM4605AC > > HDD Expansion Pack for px12-350r with 4HD x 3TB Serial Number: 742709357572 YHG91GLA YHG2AW5A YHG98WMA YHG8TBTA
SOURCE: Serial number missing
The volume serial number is automatically generated when you format the drive. By using the Seagate utility to zero fill the drive, you have made it blank and destroyed all data, including the partition table and filesystem. Re-partition and re-format the drive.
SOURCE: Changing HDD Serial Number
It is not the volume ID that I'm talking about. Its the HDD Physical's Serial Number. The one that is assigned by the manufacturer.
SOURCE: Hi, I have brought seagate
Try going into the Device Manager and look under USB Controllers. It may be disabled there and just needs to be enabled again.
SOURCE: my toshiba HDD (Model-MK3265GSX) Serial
It's possible to recover the data to any target hard drive, assuming the data is recoverable. Unless you have the appropriate knowledge, and software and/or hardware tools to recover the data yourself, you should probably contact an expert. The cost of data recovery will depend on the severity of the damage to the drive and can range from several hundred dollars to several thousand. If you have more questions, feel free to message me directly.
SOURCE: I have a Iomega 250GBExternal
This Iomega DA-30C03 power adapters. It has two different version. One require 12V 5V 5 pins power supply, and another need 12V 5V 4pins connectors. Under same model number, but, different version.
you can find those two version adapter as below link:
http://www.powerpayless.com/iomega-da-30c03-ac-dc-power-adapter-din-4pin-equiv.html
http://www.powerpayless.com/iomega-da-30c03-30941702-ac-dc-power-adapter-with-5pin-equiv.html
