Question about Epson Stylus R265 InkJet Photo Printer
EPSON r265 will not take compatable catrages
Posted by 1jess on
  • rooster0_3 Dec 12, 2007
    my two red lights keep flashing when i turn it on????
  • Anonymous Dec 30, 2007
    Yes the Epson r265 keep switching off the ick . help help eating cash.
Anonymous
    Problem Solver:
  • 7 Answers
I had the same problem
the problem are the chips..epson changes the type of chips after a few month
you get CISS with the right chips on the ebay-platform from
a dealer name: tinte 24 he is very good in service to costmers even when you have problems
Posted on Dec 05, 2007
Anonymous
    Genius:
  • 2,985 Answers
Save the Emoty Eosin Cartriges and change the chips over.
You will have to get a ZapIt device to 'Zero' the chips - available from your supplier
Posted on Nov 18, 2007
RESETTING COUNTER ON EPSON R265. I run windows 7. The count resetting utilty does not work as it was intended for earlier versions of Windows. I have looked for the up to date SSC but the 4.5 version does...
Try to do this, right click on the resetting program icon and click on troubleshoot compatibility, then click on "try recommended setting"... click yes to open the program... the program will run, try to reset your printer... save the setting when your done.
Goodluck.
Jul 16, 2010 | Epson Stylus R265 InkJet Photo Printer
My r265 wont accept compatable ink cartridges is there a setting to change this so i can use them?
mcdevito75 here, Best Bet type in Epson inkjet printer in search and ask the computer if these compatable cartridges can be used and how.
Jun 23, 2010 | Epson Stylus R265 InkJet Photo Printer
My Epson Stylus Photo R265 is not allowing IJT Direct compatible ink cassettes to be used - they load into the printer OK. What can I do to make them work?
The compatable inks you use will depend on how old your printer is
Epson change their printer every few months changing the chips so if you have a very early printer you need the earlier chipped compatables
Feb 21, 2010 | Epson Stylus R265 InkJet Photo Printer
Hi, I have just changed the yellow cartridge on my R265 with proper epson ink cartridge and it is saying that it is incompatible. Can you help please?
Hi If you are using compatable inks try taking the ink cartridge out and put it back in again try this three or four times to see if it will accept it if not try a different cartridge you can sometimes get a duff one The earlier models have a different cartridge than the later models epson altered them and changed the chip
Oct 25, 2009 | Epson Stylus R265 InkJet Photo Printer
2 red lights are flashing on my printer epson R265(END OF LIFE TIME SERVICE)
U can find resetter (SSC Utility or R265 Adjusment) at indoreset.blogspot.com. Reset the waste ink counter.Good luck.
May 29, 2009 | Epson Stylus R265 InkJet Photo Printer
Epson R265 Ink pad full
I have problem with r265 Epson. I installed new ink cartridge from epson but the printer could not recognize it. I installed SSC Service utilitry, but the programme could not recognize printer at this status. What can I do?
Nov 03, 2008 | Epson Stylus R265 InkJet Photo Printer
Printing too dark
Check the properties of the printer in Windows, make sure it's not using any odd color profiles. My Epson uses E411__1 as it's color profile. There might also be brightness and contrast sliders in the printing preferences that you can adjust or return to default.
Aug 12, 2008 | Epson Stylus R265 InkJet Photo Printer
Epson r265
Hi - What type of discs are you using? I have an Epson 200 series printer and use these discs click here.
Also what ink are you using as some "compatible" inks do not work well on printable discs.
Best regards,
Informatica
Jul 03, 2008 | Epson Stylus R265 InkJet Photo Printer
Epson R265 printer
ive had this problem too try putting the pollystyrene that holds the top of cartridge during transit back in when inserting cartridge into printer i found this worked for me
Feb 01, 2008 | Epson Stylus R265 InkJet Photo Printer
I need help
Nov 10, 2007 | Epson Stylus R265 InkJet Photo Printer
Epson Stylus R265 InkJet Photo Printer Logo
54 people viewed this question
Top Epson Office Equipment & Supplies Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
