Sounds like from your info you have a stopped up drain line. When you say tray I am not sure what you are going to empty. Does the unit empty into a condensate pump. If so sounds like you have a pump problem. If you have a small pan underneath the ac unit with a small float. If this is filling up. You have a stopped up drain. If you can blow out the drain from the inside good. If not the best way is to take a shop vac and **** from the outside drain line. BEST pulls everything out. Rus
