KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Why is the display information dim?
Can not read the display information because it is very faint.
Display very faint, working but need to place a light over it to read the display.
I have read your article; it is very instructive and valuable to me. I admire the valuable information you offer in your articles. Thanks for posting it. Custom Packaging Boxes
1helpful
Proform 775 ekg control panel very dim, hard to read display
sounds like the back light is bad, not sure what type of screen that is. but most screens have a back light for them, they will go bad over time,
Why is the display screen on my phone so faint?
the back light has failed. take it to a phone repairer or buy a new one.
Very dim display..so dark that all I see is a faint picture. Are bad capacitors to blame?
I would say either the video cable has disconneted, causeing the led that lights the screen up to not function,, simpley take the bezel around the screen, take the small screws aroud the screen to slightley pull the screen away from the back top to see if the cable is, or has pulled loose...If now the screen is bad..
My Toshiba L645D-S4030 is running fine, but the display is extremely dimly lit. I can faintly see the wallpaper on the screen and can faintly see icons/menus when I roll mouse over them, but its too dark...
Most likely the LCD inverter has gone bad. This is the part that provides power to the back-light of the display. In order to replace it, you'll have to get the part number of the LCD. Be aware, they used different LCD in the same size display. It will require removing the bezel and removing the screws that hold the LCD in place so you can get to the back to read the part number of the LCD. The inverter shouldn't cost that much, but if you have a shop do the repair, you're looking at $125-$175. good luck.
If this information was helpful, Please rate it high. thanks
The digital panel is very faint and hard to read on my Moms Whirlpool Range . The #'s are RF376PXDN1 and FF 1913385
usually when a display is dead one must replace the clock assembly to get the unit to work properly, those clocks arer known for going dim and being defective.....the research i did showed that those parts arent available anymore so i would just use it unitil u want to replace the unit, hope this helps
My display lights on my Mercedes Benz Audio 10 dims especially at night when i switch on my lights. The raido/cd player still works but the display is either very faint or off. The vehicle is a C200...
You can go to a auto zone or a mercedes authorized repair shop and have them hook it the machine and do a computer read and test it will tell what the problem is if you go to Auto zone I dunno If you have one its free anywhere else they may charge.
Dim Panel Lites
Only fix is to replace display board. This may be a seperate board, but often is part of the range control board.
Top KitchenAid Refrigerators Experts
vince
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
