It wont let me log in to find out it says i do not have permission and a resticted site
SOURCE: yahoo messenger 81003005 problem
To get away from errors you need to use YM8.1
Messenger "9" 1st version was in Beta (testing) form. The newest version is not, But it's not working well either. Stick to 8.1 until they work out the Bugs. Including people using 8.1 trying to message ones with 9 or reverse they are having compatibility problems; like text not showing,pictures not showing. It shuts down on Vista users , not allowing people to log in.Web cams do not always work. Many things do not work or are missing that YM 8.1 has. It Seems for Vista users it is so buggy Yahoo is giving up on it and are no longer trying to fix it. http://www.ymessengerblog.com/blog/2008/...
Download 8.1 here;
Yahoo 8.1: http://www.soft32.com/download_30.html.....
Use this method: Start,My PC, C drive, open Program files.Next open Yahoo file then Messenger file.Click on UNWISE to Un install messenger 9 completely. Do not just delete yahoo file as this can cause problems with other Yahoo programs.
Your contacts list and messages are stored online and will be there when you return to 8.1 messenger.
Another big problem is with the latest update for Flash Player
Flash player 10 Does have conflicts,and 9's latest update 9.0.124.0 Can have conflicts with Yahoo(very rarely, if you are using it with no problems keep it) and is causing some Yahoo Messenger services to not load.Use the link below for a download of Flash player #9.0.115.0 It should work as it's the latest before 9.0.124.0 . You have to remove the present flash player,add/remove programs in control panel, then download the older version.
http://www.soft32.com/download_500.html....
More help can be found here; http://www.freecreed.com/userid.html...
3 weeks ago
Source(s):
Soft 32 is showing "errors" on the link. updated links;
Download 8.1 here http://www.filehippo.com/download_yahoo_...
http://www.adobe.com/support/flashplayer...
Do you have Yahoo messenger enabled on your phone? if not you need to call your cell phone company and have them enable it.......hope this helps! please rate my answer if this solves your problem ty :)
SOURCE: cant log in my yahoo messenger in my pc
cant sign into my messenger and it wont let me download an updated version either
SOURCE: Y! messenger on blackberry
YM can also experience technical glitch sometimes. I also experience it often though I have a fast internet connection.
SOURCE: Cannot Log into Yahhoo messenger
1. First, ensure that your computer is connected to the Internet.
2. Confirm that your password is not hacked by loging into your yahoo email account with the same user ID that your using to login to the yahoo messenger, by going to http://mail.yahoo.com.
3. If you are able to log into your email account, your ID is safe.
4. Try to kill yahoo messenger on your system using "Task Manager"
5. To open Task Manager, right click on your computer's task bar at the bottom and click on "Task Manager".
6. Next, click on the "Process" tab in Task Manager, select "YahooMessenger.exe" and click on "End Process" button.
7. If you cannot find "YahooMessenger.exe", then select "Ymsgr_tray.exe" and click on "end process".
8. Now start your yahoo messenger again and try to login. You should be able to login succesfully.
9. If your Internet connection is fine and you have followed the above-mentioned process and still cannot login to yahoo messenger, your system's fire wall is probably obstructing yahoo messenger to access internet.
10. Change the necessary settings on your firewall to leverage access to yahoo messenger.
