Nokia N70 Smartphone Logo
Posted on Jul 04, 2009
Because it's phone memory full i cant open my mobile and it is only appear white screen.. how can i open and delete some data or to reset my mobile phone?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 16, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
81
Points
I forgot my security code, How can i open my phone memory, my model no.is 6070
How can I open phone lock Samsung gt 3303i the imei no 359091/04/140465/4
Only those who have gsm gadget (a gsm box and a modified cable) can read the phone lock code(mobile phone technicians).
The only way to remove the phone lock code is by resetting or formatting the phone.To do this just simply follow this guide.
* turn off the phone and make sure battery life is at least 50%
* simcard and memory card
* turn the phone On and wait until insert sim appears on home screen
* tap "call" button then type this ----> *2767*3855#
* a black screen and eeprom reset appears,wait until the phone process is done and it will automatically restart your phone.
Now your phone is back to its original settings and all codes is reset to 00000000 (8 zeros) including phone lock code.
Take note that this procedure will delete all data in your phone,If you don't want important data to be deleted(such as contacts,calendars,messages etc.) then it is better to bring the phone to the nearest mobile phone shop near you and they will do it without deleting any of your important data.
My lg gt400 mobile user memory is full and cannot delete it
connect the phone to a computer using the blutooth usb lead
once connected click start all programs accessories open windows explorer you should see phone it might be listed as a mass storage device click to open then click on the card select the data either delete or right click select format
hope it helps
3helpful
3answers
How to format nokia N79 phone?
1) Factory defaults-
Type *#7780# on your standby screen.
This will reset all your setting to default factory settings. User data wont be affected. (Default Lock code is 12345)
2) Soft reset-
Type *#7370#
This will reset the phone as well delete user data. Use when want to format the phone.
Cant open setting wizard n73 memory full delete some data appear problem:
hi ,
try first to reset your phone by typing *#7370# ,it will ask for locked code then enter it...(if not change ,the default is 12345 ...wait until it reboot...
i hope it will help you ,thanks for trusting fixya
Apr 13, 2011 • Cell Phones
2answers
I canT recieve and send a messaage because my phone says that ' memory full, delete some data first" and i didn"t know how to delete that said data.
you need to delete some of your texts also go to your setting and click auto delete on it will delete the last one everytime you fill up your box so you will never run out of space.
1helpful
2answers
I also have the same problem with my nokia n73 m. It shows memory low delet some data.
Reset your phone. Enter *#7370# from standby screen. Then it request the code is 12345. Or turn off your phone, and then hold *+3+ call button (green button). And turn on your phone. Keep holding until the word nokia is appearing.
CAUTION: IT WILL DELET ALL OF YOUR DATA IN PHONE MEMORY. So, please make a backup first. Please rate us in fixya if i'm helpful
7helpful
I have nokia c5 but web does not open,shows errer not enough memory to perform operation,delete some data first. what is the solution and how to delete the data
This is what you get when you fill up the phone memory too much. There is not enough virtual memory to run the web application.
The best way to go about this is to do or run a complete format of your phone memory. It is quite useful for you to know that running a format would wipe out everything on your phone memory.
If you want to go ahead, you can follow the instructions below
1.- Basic Reset or Soft Reset This option restores the .ini files from the ROM.
Does not erase data (photos, videos, documents) nor applications from
a third party. Key Code *#7780# (click this combination of keys on the
keyboard in the mobile)
2.- Total Reset or Hard Reset This option restores the original operating system from the ROM.
Formats the C: partition and deletes all data including the memory
card. Key Code *#7370# (click this combination of keys on the keyboard
in the mobile)
You can also reset the phone by doing the 3 button reset.
To do this, you have to turn off your phone.
Hold the *(asterisk) button + the green/call button and the number 3 button then turn on the phone whilst holding these 3 buttons. Wait till the phone comes up with the initial set-up screen.
Note that you must have full battery or have your phone connected to power before doing this.
Hope this solution was helpful? Please comment for more information
2answers
Why i can't open my mobile phone?
chip absent because not flash so what is the problem
2answers
My n73 phone always appear in the screen memory is full
There is one solution go to settings>restore factory deafaults.if not sucses delete one by one all the messages.
Top Nokia Computers & Internet Experts
k24674
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
