How to use therostat
They use a 120v thermostat you should be able to buy one wherever you bought the baseboard heaters. Be aware those heaters costs a lot of money to run and dry out your house like a desert buy a few room humidifiers when you get the thermostat. Make sure you use the correct size wiring to the baseboard heaters and the Tstat if you undersize the wires for the breakers involved you'll more than likely cause a electrical fire.
Posted on Nov 22, 2014
SOURCE: 3 bsbrd heaters connected to one therostat(honeywell) trips main
I had this problem once in an apartment I own. it was an EXTREMELY ease fix. my problem as that the set screws in the breakers were not tightened enough, and would cause heat to build up, and trip the breakers. so..... first try to tighten the set screws on your breakers.
Posted on Sep 29, 2009
Feb 15, 2016 | Cars & Trucks
Jan 17, 2016 | Water Heaters
Jan 01, 2012 | Marley Electric Hydronic Baseboard Heater,...
Aug 30, 2010 | Fahrenheat Electric Convector Baseboard...
May 29, 2017 | Honeywell Heating & Cooling
Oct 04, 2009 | Fahrenheat FBE15002 Baseboard Heater
Feb 14, 2009 | Fahrenheat PHH15002 Oil Filled Baseboard...
Jan 16, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Nov 19, 2017 | Heating & Cooling
Sep 11, 2008 | Fahrenheat PHH15002 Oil Filled Baseboard...
133 people viewed this question
