Question about Siemens Gigaset 2420 Cordless Phone
How do I obtaindially tone. Battery charged and connected tolandline
Ignition system is not getting any power. I replaced my battery and still no power. The key doesn't even trigger the door ajar tone. I checked all fuses and connections. Could it be a sensor or a part
Make sure your battery is fully charged.You have some power so your battery or connections may be bad.You may have a fried fusible link.I cant tell you where it is located though.Check your cable connections at the starter and the ground at the end opposite the battery.
Mar 17, 2013 | Cars & Trucks
No dial tone on a cordless phone
Some units if the battery is not fully charged or any ac adaptor for another phone also connected is not plugged in you will now have no dial tone.
Dec 15, 2012 | GE Lands Phones
No dial tone but dial tone on hands free
The battery in the handset may be faulty/flat. If it does not charge up then replace the battery.
Feb 06, 2012 | Lands Phones
The phone lights up when put to charge also the red light on the base,, but when the phone line is connected it wont work ..What do u think is the problem?
The battery in the handset could be bad . First I would test that the base unit is recieving dial tone by pressing speaker button on base unit. If there is dial tone then problem is in handset or in base unit communication to handset. Try resetting power to base unit. Check manual for any re-initialization procedure. If the base unit is not receiving dial tone then I would test that the phone line is delivering dial tone to the base unit by connecting a known good phone to the line cord. If the dial tone is not present , problem could be in line cord from outlet, outlet, building wiring, or service provider.
Dec 08, 2010 | Uniden Cordless Phone
Can not get a dial tone
maybe someting to do with freqencies
Feb 23, 2018 | AT&T E2717B Twin Cordless Phone
Wont connect
replace battery
Mar 14, 2009 | Lands Phones
BATTERY CHARGE
So you had the system is storage? If that is the case then it is probably time to change the battery. Storing batteries when they aren't fully charged, or in extreme temperatures can damage the battery. You can check out http://www.batteryinternational.com/ups-batteries.html for a replacement .
Mar 01, 2009 | Dell Back-UPS ES 650 (DL650T) UPS System
No dial tone
If you got this second hand more than likely the battery in the hand set is dead. Batteries Plus has batteries for EVERYTHING.
Nov 22, 2017 | GE 26928GE2 Cordless Phone
Dell dj mp3 player won't charge
You need to install the Playforsure firmware update. That will solve the problems.
Nov 07, 2007 | Dell DJ MP3 Player
Siemens Gigaset 2420 Cordless Phone Logo
Top Siemens Lands Phones Experts
Bruce Robin
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
