Panasonic Viera TC46PGT24 3D Plasma TV Logo
A
Anonymous Posted on Oct 01, 2014
I have a Panasonic Viera 3D Plasma TV. While watching it I heard a small pop and then no picture. When trying to turn it on again it began to blink (over time I counted 10 blinks per pause). In man
I have a Panasonic Viera 3D Plasma TV. While watching it I heard a small pop and then no picture. When trying to turn it on again it began to blink (over time I counted 10 blinks per pause). In many of the forums I have read they recommend to open the back and carefully clean and removed dust and then plug back in and turn it back on. If that didn't work to hold it down and reset it. Having done that several times and not having success I find myself wondering if it is worth bringing it into a tv shop or even buying a replacement part for what ever needs replacing. With this 10 blinking signal what would I need to replace? and how would I go about it? Is it an easy enough to do it yourself or is it too complicated?
vsluc
Level 1:
New Friend:
  • Contributor 33 Answers
  • Posted on Oct 08, 2014
vsluc
Contributor
Level 1:
New Friend:
Answers
33
Questions
0
Helped
11902
Points
45
10 blinks indicate power supply problem
5 Related Answers
Anonymous
  • Posted on Apr 21, 2009
SOURCE: Panasonic TH-42PX60U plasma TV: red blinking light
are you using a PC to feed a signal or maybe a cable with an adapter?
I had the same issue when I used one of the rear HDMI ports to show a PC display. Apparently there is a software difference between the rear and side/front ports. Inputting the PC through the side HDMI port has solved the problem for me (so far!)
Anonymous
  • 11 Answers
  • Posted on May 14, 2009
SOURCE: 50 inch Plasma panasonic TH-50PZ80U.
if you have a warranty let them check it out before opening the panels, it may void it.... may be an internal power short.
Steve LaHuis
  • 418 Answers
  • Posted on May 02, 2010
SOURCE: panasonic 42
Loss of power from power supply. Usually bad power supply.
Chi Chu
  • 8457 Answers
  • Posted on Jun 22, 2010
SOURCE: plasma 50 inches dont turn on
The power supply board is dead.Tries the websites like Shopjimmy.com,Ebay.com to buy the refurbish power supply board for the replacement.
Anonymous
  • 72 Answers
  • Posted on Jul 03, 2010
SOURCE: 10 red blinking lights on my Panasonic Plasma TV,
This is a power supply issue - found a company that has used power supplies, they sell them for $60.00. We recommend a professional install the board because the voltage needs to be adjusted after the install or you could damage something else. The high voltage in the set can KILL you soe be very careful. The web address for the PS board is plasmafix.com.
Panasonic viera plasma tv 10 blink code
1. Hold the front panel power button for over 15~20 sec and try.
2. See the youtube video
https://www.youtube.com/watch?v=awnrE3k_G2M
1helpful
No picture showing after power on.
If this does not happen with other devices then I would say try a new video cable. HDMI cables can get very picky. If this happens at anytime then the inverter in TV is going out.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Why does my Panasonic Viera VT50 have no picture and red led blinks 3 times
First thing, check the HDMI input and make sure it is firmly connected, same for the power cable, obviously. My Samsung goes similarly nuts if it detects no signal from the currently selected input but after 1-2 minutes it eventually stops and I can change the input source.
Repair power board
How do you know that it's the problem? Do you hear the relays come on? Does your tv blink? How many blinks? That is a vital part in diagnosing a panasonic tv.
Regards,
Joseph Van Buren
Viera tc-p50ut50 light blinking eight times
One the circuits popped. you can locate the bad board and replace. Use these charts to help locate the problem.
No picture and power light blinks 7 times on my viera tc-p50st30 plasma tv when it is turned on
That can be caused by either the SC or SD board. Contact the people at www.tvrepairworld.com they can assist with proper diagnosis and they also should have the replacement board
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
