Question about Brookstone iConvert Slide and Negative Digital Scanner for PC and M
What driver do I need to run Brookstone Slide and negative scanner Model SKU634402 for Windows 7
1 Related Answer
Anonymous
SOURCE: Help! We opened the
A search for that model on Brookstone's website takes me to the iConvert Instant Slide and Negative Scanner. That scanner does not require an installation CD. It works by scanning slides or negatives and then saving them to an SD card. Many digital cameras use SD cards so you may have one already. Otherwise an SD card will need to be purchased separately.
Posted on Feb 28, 2011
I can not get the Brookstone scanner mouse to install on a Windows 7 Professional Laptop?
Make sure you install with administrator privileges (right click run as administrator)
http://www.brookstone.com/webassets/downloads/ScannerMouse_817873/windows-driver_817873p.exe
why not disconnect the mouse and use the trackpad/buttons until it asks you to connect it?
Need windows 7 drivers for Bell and Howell 50134
unfortuantely MS has not made a Legacy driver for this product. it would be best to just have an XP partition on the Windows7 box that allows you to operate this program.
1helpful
Help! We opened the box for our new Brookstone Slide and Negative Scanner Model # SKU634402 and the installation CD was missing. Is there online installation available or should we just return the item...
I have one of your Brookstone iConvert Slide and Negative Scanner, item # 598581. I have had it for awhile and when i finally wanted to install the software last month, it did not work. The software is for...
I have one of these scanners. I scan my slides to a SD card, put it in the slot in my Gateway computer and copy the files to a folder on my computer. Some pictures need fixing for color balance. I use Photoshop Elements to make the necessary adjustments..
I need software for iconvert software for a scanner I bought at brookstone. It did not come with a cd. Please help me
I had the same problem I found that the missing CD is downloadable on the Brookstone website.
http://brookstonemanuals.com/
Product number for Brookstone "Slide and Negative Scanner" is 598581 ... see back of your manual to confirm.
iConvert Film & Slide Scanner (598581) iConvert Film & Slide Scanner Drivers for Windows XP & Vista (119 MB)
Worked great for me!
Is there an instruction book for the Brookstone iConvert?
Hi, you can download the manual for the Brookstone Scanner here:
http://www.brookstone.com/linkedassetservlet?assetId=323330&languageId=EN
If this answer helped you, please leave a positive feedback. Thanks.
3helpful
Brookstone iConvert Slide and Negative Digital Scanner for PC and M Logo
Top Brookstone Office Equipment & Supplies Experts
Ekse
Are you a Brookstone Office Equipment and Supply Expert? Answer questions, earn points and help others
