Question about Gold Medal Kitchen Appliances - Others
Why is my gold medal popcorn model # 2552 machine not heating to pop popcorn anymore?
Model # 2552
Tim Eischens
    Champion:
  • 252 Answers
A kettle not heating is either a switch, kettle wires, thermostat, or kettle heater.
Check that the kettle is plugged in tight, notice if the switch lights up when switched, then contact your local gold medal dealer for repairs. It is always cheaper to repair a gold medal kettle than replace.
http://www.gmpopcorn.com/domestic-dealers.cfm
Posted on Nov 25, 2014
5 Related Answers
Adavoid
  • 25 Answers
SOURCE: Trips circuit when you turn on the Kettle heat
When the fuse blows see what else in the house is out, maybe you have the circuit overloaded. Try putting the popcorn maker on a different unused curcuit to see if it still blows. Then you will know if it is the popcorn maker.
Posted on Dec 16, 2008
Anonymous
  • 109 Answers
SOURCE: How much oil and popcorn kernels to use in gold medal machine
Try one ounce of oil, 1/2 teaspoon popcorn salt and 1/2 cup of popcorn and see how much it fills your machine and adjust quantities from there. This will usually fill a wok size bowl.
Posted on Mar 29, 2009
Anonymous
SOURCE: I have a Gold Medal Popcorn Machine 2086. The
I hate to put this as a solution because it really isn't. I have an old popper needing a new kettle and was told it was almost as much to purchase a new kettle than the whole machine. The kettle is almost the entire cost of the unit. I will be purchasing a new unit.
Posted on Jun 23, 2009
SOURCE: Need model number for Gold Medal popper
http://www.concessionpalace.com/concession-tutorials/P-60_60_Special_Uncle_Walts-1866_2085_2086_2656-popcorn-machines.pdf
Posted on Oct 09, 2010
rickead1
Rick Ead
  • 1998 Answers
SOURCE: Gold Medal Products Whiz Bang
Have you checked to assure that the warmer switch and the kettle heat switch are both functioning properly? Also the timer on the bucket seasoning pump control box determines the length of time the heat element of the bucket pump is at HIGH HEAT i also suggest you take a look at this pdf of the manual of your machine under the troubleshooting guide area if you have any further questions please message me back and please remember to rank how this opinion has helped in your appliance situation Thanks again
Rick
http://lib.store.yahoo.net/lib/yhst-81132447584496/47699.pdf
Posted on Dec 21, 2010
Our store owns a gold medal #2656 popcorn popper but now it will not pop but few kernels. is it not getting hot enough or is it something else?
no you shouldn't have to do that. you are correct about the heat. what happens is it doesnt get hot enough for the moisture in the seed to expand to pop it, but its hot enough to dry it out so it cant pop. so it burns instead and you end up with a bunch of old maids. the thermostat is the first place to check.
Feb 05, 2016 | Gold Medal Products Gold Medal 2656 6 oz....
Gold Medal Deluxe Pinto Pop Popcorn Machine Model 2147 will not heat up
If the switch is OK and you have. Power at the kettle plug and you are not getting any heat it's one of 3 things. Burned wire inside the kettle. this is common. Or it could be the thermostat is bad or the element itself is out?
May 07, 2014 | Gold Medal Products Gold Medal 2147 120208...
How to install a stir rod in a Gold Medal Product, Deluxe Pinto Pop, model 2147
Take the kettle crossbar assy off the kettle and look and see if there is a set collar above the shaft weight. If so loosen it so you can slide the weight up...enough to get the old one out and the new one in.
Mar 31, 2014 | Gold Medal Products Gold Medal 2147 120208...
How much oil, corn and salt do I put in a 2085cl gold medal popcorn machine?
That model is a 6oz popcorn machine.
3/4 cup popcorn kernels (6oz)
slight 1/4 cup oil (1.6oz-a quarter cup is 2 oz.)
1 teaspoon popcorn salt.
Sep 17, 2013 | Gold Medal Kitchen Appliances - Others
We need operator's manual for Gold Medal Astro-Pop model 2012
Gold Medal Model number 2012 is for a 28x48 4 wheel cart only, it is not a popcorn machine.
Astro Pops are model 2010, have been for 30+ years.
Their Manuals are not publicly available because they have changed many, many times and the odds of you getting the correct one is slim.
What parts are you looking for? and what is the manufacture date of the machine?, the serial plate is in the lower right hand corner of the cabinet, behind the cart doors if there are doors.
Feb 25, 2013 | Gold Medal Products Astro Pop Popcorn...
I have 2003 model whiz bang popcorn machine that takes forever to pop the corn
Old popcorn is the first thing to check, and that you are measuring correctly. 12oz of popcorn is the correct amount in a 3 min popping cycle. always time the 2nd batch.
That model popper has 2 heat elements, and 2 thermo stats that control them. If the first 2 things to check are good, then you dropped a thermo stat or heater and it is operating on 1 heater instead of 2.
Jan 21, 2013 | Gold Medal 2003 Whiz Bang Popcorn Maker
I need parts for Gold Medal Bronco Pop 2152
What is the age of the machine? or if you can post a picture of the Kettle itself I should be able to help you out.
Nov 24, 2012 | Gold Medal 2152 Bronco Popcorn Maker
I have a Pop-A-Lot model 2007, serial DAU-S- 4591 where can I buy a new stirring shaft and the bronze bearing that it rides in?
Any stocking Gold Medal dealer should have parts for you. You will need to buy the agitator and cross-bar assembly, the bearing is generally not sold separately.
Gold Medal products
Oct 06, 2012 | Gold Medal 2007 Pop-A-Lot Popcorn Maker
Sep 01, 2009 | Gold Medal Kitchen Appliances - Others
Kitchen Appliances - Others Logo
388 people viewed this question
Top Gold Medal Kitchen Appliances - Others Experts
Adavoid
Level 1 Expert
john h
Tom Chichester
Are you a Gold Medal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
