Dell inspiron 3521 code error 2000-0333 hearing a
Dell inspiron 3521 code error 2000-0333 hearing a beep sound while turn on pc, pls tell me how do I fix it?
stephen Adams
  • 2,219 Answers
There is a WIKI knowledgebase article on Dell error codes here
Beep Codes and PSA Diagnostic Chart Desktop Wiki Desktop Dell Community
It say this is due to "Graphics test timed out waiting for keyboard response."
Dells advice is to "Remove and reinstall the video card on a Desktop Computer for this error codes."
You can get a solution for the PSA error code at this Dell website.
Dell Technical Support
Posted on Feb 08, 2015
1 Related Answer
Anonymous
  • 4 Answers
SOURCE: dell inspiron 1520 error code 2000-0146
I had the same problem and came across this solution that worked for me as well:
Re: windows Vista will not start 18 Aug 2009 07:28PM I was getting a the same error codes and couldn't get Windows to boot up at all. I went to BIOS set up (restart your computer and hit F12 when the BIOS screen comes up), went to onboard devices and changed the SATA Operations from ACHSI (don't know how it got there) to the factory default setting ATA. Then I started up in "repair mode" (which was an option that was coming up when I tried to boot up before but never worked) - it went through a repair check and went to login screen.
Prior to finding this - I tried several things including start up from the Reinstallation disc, but nothing worked. I was ready to buy a new hard drive, but don't have to. Works fine!
Not sure what caused the problem to start with. It is an "Inspiron 1520"
Posted on Aug 21, 2009
My charger went bad. ordered a new one. but I hear 5 beeps constantly, what should I do
need to resolve laptop brand and model.Ex .dell inspiron 3521 5 beeps means RTC Error. need to replace the CMOS Battery and check. if not working pls check south bridge is heat up.
if heat up need to use cons to set heavy load to chip and (3 coins) pls use hot gun to resold the chip.
May 05, 2017 | Computers & Internet
My Dell laptop makes 12 beeps and won't start, why?
Most likely one of the components on the motherboard has fried.
One other thing to try that probably won't fix your problem. Is to take out the battery and try it plugged in. That way it will tell you if a bad battery is pulling down the power supply or the power supply is dead and it's trying to run on the last of the battery power.
If the screen stays black throughout the power-up then it most likely isn't the hard drive and you'll be able to get your information out of it with an adapter and a little work. (as long as it's not encrypted)
Jul 31, 2016 | Dell Computers & Internet
How to boot dell inspiron one 2020 when it only beeps
the number of beeps will tell you what the problem is the beeps are an error code here are the code list for your computer
Beep Code Description No Beeps No Power, Loose Card, or Short. 1 Short Beep Normal POST, computer is ok. 2 Short Beep POST error, review screen for error code. Continuous Beep No Power, Loose Card, or Short. Repeating Short Beep No Power, Loose Card, or Short. One Long and one Short Beep Motherboard issue. One Long and Two Short Beeps Video (Mono/CGA Display Circuitry) issue. One Long and Three Short Beeps. Video (EGA) Display Circuitry. Three Long Beeps Keyboard or Keyboard card error. One Beep, Blank or Incorrect Display Video Display Circuitry.
May 25, 2014 | Dell Inspiron One 2020 All-in-One Desktop
I bought a dell inspiron 15 3521 and i am having problem with the drivers
you can always find dell drivers on their website. the ones for ubuntu will not work in windows. windows 7 64 bit are on this page http://www.dell.com/support/troubleshooting/uk/en/ukdhs1/Product/inspiron-15-3521
Jul 17, 2013 | Dell Inspiron 15 3521 15.6" Laptop...
My house power went off and when it came back , i am not able to switch on my desktop. All i hear after i power on my desktop is the fan noise and the beep sound. Pls help
If you hear exactly ONE beep, it means that your computer-hardware (power-supply, CPU, motherboard) is OK.
Multiple beeps are "bad" -- they identify different errors.
If Windows does not "boot", then the power-surge may have damaged your 'C:' drive. Ouch!
Jul 18, 2010 | Dell Inspiron 530 Desktop Computer
Inspiron 1100 wont boot up,screen stays black,i can hear the fan running,sounds like hd is starting
STEP: Run the Preboot System Assessment (PSA)
Additional Information
  1. Ensure that the computer is powered off.
  2. Press and hold <Fn> and press the power button to power the computer on.
  3. Release both buttons. The PSA diagnostics sequence begins.
  4. Make note of any PSA beep codes or PSA error codes
Check for PSA Error codes on support.dell.com.
If all Test Passed. Then Perform Dell Factory restore or OSRI.
Jan 20, 2010 | Dell Inspiron 1100 Notebook
Computers & Internet Logo
311 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
