You didn't tell us what make and model you're asking about, but generally if you contact the customer service department of the company that made the unit, they will supply the schematics for their devices.
Behringer will not release schematics unless you are an authorized service agent... however, sometimes you can make do with the few schematics floating around... What is the problem with the unit? They typically use a switching power supply and the schematics of those aree usually similar enough to repair them.
You probably need to replace the filter caps on the power supply. You might want to vist the organforum.com for discussion. You can find schematics to download at captainfoldback ... search google for hammod schematics and that site should be listed. Some capps are available form antiqueelectronic supply... search google for that. or go here: http://www.tubesandmore.com/
Scroll down to "Get Manual" and click to download. On page 2 is the SPS400 power supply which is one of the smaller switching supplies they use. You may find the schematic is close, possibly they de-populate it as a smaller supply. When repaired, start the supply for testing with a 60 watt light bulb in series with the power input. Use an isolation transformer for troubleshooting for safety.
Scroll down to the little link "Get Manual" and download the service manual and schematic. You will find the power input in the upper left corner of page 5.
Most of the problems with the small guitar amps are blown power amp chips. They usually use chips like the TDA2030 which look like a power transistor.
Most other problems involve broken connectors, bad solder joints or cracked circuit boards. The power supply area is so simple one doesn't need a schematic for that part which is usually just three terminal regulators for +/-15 volts. Schematics are often hard to find.
Try this site, although this is a different model, much of the schematic will likely be the same.
Try contacting their service center rep at (801)566-8800. They might send you a schematic for the pedal if you explain your situation. They do recommend using the original power supply PS0912 which should still be available. Hope this helps.
Try contacting the service center rep at (801)566-8800. They might send you a schematic for the pedal if you explain your situation. They do recommend using the original power supply which is PS0912.
