The oven quit working on our kenmore stove. The cook top all works just fine. All the controls indicate it is working. No error codes display. But the elements for both the top and the bottom are not heating up. Is there a fuse? Can't picture both top and bottom elements going bad at the same time.
SOURCE: oven elements dont work / stove top works fine
Repair person also shut the power off before replacing the fuse...
SOURCE: I have a Kenmore Stove
You could very well have an Electronic Oven Control (EOC) board problem. There two separate circuits that control the oven BAKE and BROIL functions. If you have replaced the BAKE element, and have ensured it connected properly, the only other component that controls that function, is the EOC. If you post back with your complete model number, I can double check to make sure. The model number will be located on a nameplate somewhere around the oven door opening or lower drawer opening. The reason I need to confirm is because some ranges have a separate relay control board.
SOURCE: Oven heat
There is a bottom hidden element that is the main element used for baking and cleaning. If its not heating then the element has gone bad and needs replacing. If you have a volt meter then you can confirm this by checking the voltage between the two terminals sticking out of the rear of the range. There should be 240vac across the two. If you have that then you need a new element if you don't then you need a new control board.
SOURCE: frigidaire model fef336ece.oven and broiler wont
thermostat possible open check not sure if this model has a resettable or not
