Question about Mercedes M-class Ml Ml350 Ml550 Ml63 Exterior Stainless Steel Chrome Pillar Posts Trim Set 2006 2007 2008
How do I reset brake service light on dash after replacing pad and sensor
Posted by Edward Staab on
Stan Ford
    Genius:
  • Mercedes-Benz Master
  • 2,910 Answers
There should be censer switch on the brake master cylinder . Remove this and reset by pushing the pin in , then refit
Posted on Oct 01, 2014
Thomas Beaver
  • 2,119 Answers
2005 LS lexus 430 replaced the brake pads but the warning light is still on how do i reset
Per a Google search you can't reset it. The sensors that trigger the light must be replaced w/new ones.Call the dealer for pricing on the 'brake wear sensors'.
There are 'workarounds' but I'll let you find those for yourself.
GL,
TD
Nov 06, 2013 | TPMS Scan Tool with TPR Reset Tool Kit...
I bought a 98 z3 and i need to find a diagram of the dash lights, i have a red circle light with dashes around it and i don't know what it means
it's a break pad sensor, your pads are worn out,if you wait to long, you"ll ware thru the sensor and have to replace it. it's not a hard fix, you"ll have to clear the code to remove the dash diagram, after u fix the brakes, and maybe the sensor, good luck
Mar 10, 2011 | 1998 BMW Z3 Roadster
Brake pad wear indicator light does not go off at the dash after changing rotors brake pads and the sensor in the front wheels all pads and rotors and the sensor is ok at rear. the vehicle has only 30000...
Did you change the sensor? if you did, do a battery reset (disconnect for 10 to 20 min.).
Obviously the wear sensor has made contact with the rotor and is already damaged. You're not even suppose to resuse the wear pad sensor if its worn or damaged anyways.The way how the sensor works is that it must make contact to the rotor to complete the wear pad light indicator circuit. There is no mentioning that he replaced the the wear pad sensor with a new one.
But if one did replaced the wear pad sensor and the wear pad indicator is lit up, the way to reset it is to leave the key on in ignition switch #2 or #1 for about 30sec. turn it off and its reset.
Its possible that you forgot to replace the brake light sensors. They are about 15 bucks, and have to be replaced in order for that light to turn off. You can either get them from the dealer where they'll likely charge you 3 times as much, or you can go to http://www.turnermotorsport.com and get them there.
You have to reset the light by leaving the ignition switch on position #2 for about 30 sec. turn off the ignition and start the engine up and see if it goes out. I recommend buying a new wear pad sensor as well because now light will lit up when you're way below spec (less than 3mm)
Also, you could try with this procedure for one E39: Turning off the Check Brake Linings warning on the Instrument Cluster...
- so you've just changed the brake pads on your E39, along with the wear sensors. The old sensor(s) needed replacement cause you waited a bit too long before changing the pads, and wore through the sensor(s), turning on the BRAKE light on the dash. But wait, the light is still on? But there's a new sensor installed... what gives?!
- there is a procedure required in order to turn off the light/warning. With the ignition off, step on and hold the brake pedal. Now, while holding the brake pedal down, turn on the ignition switch to position 2 (just before cranking). Hold the brake pedal until the BRAKE light is off. Tada, the warning is gone and reset.
NOTE: This procedure worked on a 2001 E46 325i. It took about 15-20 seconds, but it cleared out w/o having to unhook the battery.
Other details find in the Owners Manual 2006-BMW-Z4m-Roadster-Owner-Manual
Keep us updated.
Nov 04, 2010 | 2006 BMW Z4 Roadster
How to reset brake light after changing pads.
Hi Peters6709,
Sorry to tell you, but you need to replace the pad-wear sensors as well. They are the little trapezoid pieces that hang inside the tops of the inside pads. They should run about $10 each. Once replaced, disconnect the battery completely for about 10 minutes, if you have a stock radio keep the code handy.
Next time check the pads every 10-12K miles. I have been running the SAME pad wear sensors on my Z3 for the past 2 pad changes now after making the same mistake the first time.
Best of luck!
May 02, 2010 | 1999 BMW 323 Series
Resetting brake warning light
Hi , if you turn the ignition on so that all the dash lights are on , do not start the engine and leave on for aprox 45 seconds the brake pad warning lights should go out, regards mark
Jul 29, 2009 | 1999 BMW 328 Series
Bmw 1 serise require information on how to rest
turn on the ignition (not starting) and then press the littlie button in front of the odometer display for 10 seconds until you see the service indicator menu. use the stalk on the left and the up and down control to scroll thru to the front and rear brake pad picture and then press the end button on the stalk for 3 seconds until reset comes up, then it will show a little click spinning around, then release and press for another 3 seconds. This will extinguish the brake service light. This is the same for all service lights, but remember to turn off the ignition on and off for each reset Ie: for brake, for oil, for pollen etc. If not it might not recognize the reset. The pads on the 116i or should I say the indicator is crapo, in a extra crapo sense as it has at least 10k miles on the pad but the wear indicator shows it as need replacing, The handbrake light on symbol will be amber then red and stay on all the time until the sensor and pads are changed. Pads and sensor must be replaced together as sensor has resistance built into it it will be around 500ohms ( I think) when it has just touched and less with more wear, the new sensor is probably 1k ohms from each wire ie from one wire to the other = 1k ohms.In short the pad wear indicator is a rip off, there is a lot of life left in the pad when the sensor goes off. I estimate just above 1/3 left but more like just below 1/2.... BMW STICKING TO YOU AGAIN.
May 27, 2009 | 2005 BMW 1 Series
2004 Mini CooperS- brake service light stays on
Did they replace the brake pad wear sensor? If so, try leaving the key in the on postion for 30-45 seconds (dont start the car) This is how we reset the lights on BMW's and the Mini's use a similar system for service lights
Mar 12, 2009 | 2004 Mini Cooper
I replaced the front pads on a VW JETTA 2.5 and the check pads light is on. How can I reset the check pads light?
As the brake pads wear, the brake pad wear sensor contained in the brake pad contacts the brake rotor. This causes the sensor to fail. When a pad wear sensor fails it opens the ground circuit of the pad wear warning light system causing the pad wear warning light to illuminate. Perform normal brake service to correct this condition and be sure to replace the brake pads with pads containing wear sensors. Once the brake pads and wear sensors are replaced, reset the brake pad warning system by turning the ignition switch to the "on" position. As long as continuity to ground exists through all the brake pad wear sensors the system should reset and the pad warning light in the dash will go out. If the pad warning light does not go out, a check of the pad warning circuit for an open circuit condition or poor ground must be performed.
Mar 03, 2009 | 2005 Volkswagen Jetta
Brake Pad Sensor
i have replaced both front/ rear pads, and no matter what the dash light will not go off. I have disconnected both front/rear sensors, and light is still on , any suggestions?
Jan 20, 2009 | 2001 BMW 5 Series
Brake Pad Sensor
On my bmw 325i front pads changed,indicator on dash still on,help!!
Jun 11, 2008 | 2003 BMW 325
Mercedes M-class Ml Ml350 Ml550 Ml63 Exterior Stainless Steel Chrome Pillar Posts Trim Set 2006 2007 2008 Logo
1,085 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Bill Boyd
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
