G
Ginger Emmons Posted on Oct 01, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When copying and printing image is very light with vertical sections that don't print/copy at all. Ran the cleaning function and did a test print which came out better, but still has light strips. Tri
This is a new copier what worked great with the first toner cartridge. Only started having problems when we changed the toner.
Lawrence Oravetz
Level 3:
  • Office Equip... Master 10,558 Answers
  • Posted on Oct 01, 2014
Lawrence Oravetz
Level 3:
Answers
10558
Questions
Helped
2699391
Points
29284
Are you using the copiers toner or are you using an off brand. Makes a difference. Same with refills. Toner is not all the same.
Testimonial: "we are using the copiers toner."
5 Related Answers
Anonymous
  • 53 Answers
  • Posted on Feb 27, 2008
SOURCE: xerox 5305 copier excess toner
sounds like faulty drum cleaning blade,which is usually contained in the replacement drum module.I would be inclined to take the drum unit back where you got it (unless you replaced it with a second-hand one) 99% certain the problem is contained in that module
jtuminaro
John Tuminaro
  • 56 Answers
  • Posted on Jan 15, 2009
SOURCE: ghost printing
This machine needs a new fuser. That is a common issue.
Anonymous
  • 3085 Answers
  • Posted on Jun 16, 2009
SOURCE: black vertical line on prints and copies. 20
It appears that the Teflon is worn off of the roller. You will have to have the FUSER replaced.
Anonymous
  • Posted on Oct 05, 2009
SOURCE: Brother MFC-6800 - Mysterious Vertical Lines
This unit has a brom tube unit and need to be replacement . By repair tec.
Anonymous
  • 224 Answers
  • Posted on Mar 30, 2010
SOURCE: I have Panasonic Workio DP-2310 copier and there
check you drum charge connection between drum unit and developer unit, two metal strips at back that contact when the two unit are closed. none or bad connection means no charge and then blank copies
HP Officejet 5610 All-In-One. cartridge error: refer to device documentation to troubleshoot ... I was in the process of of printing a series of documents. does not print prpoperly
Will it color copy- stand alone? Try making a copy on the printer by itself. If the copy is still printing in blue, then go to the service section in the menus, and clean the print head, if that does not work then try the recalibrate function. -If the copy comes out fine when you try it stand alone, try deleting the printer and reinstalling the printer.
Canon image runner c5800 printing vertical lines
have you ran a test page , the test will take about 30 sheets of paper it will test everything and will correct itself
good luck
2answers
I have a Ricoh Aficio 1013 that prints fine but copies are unclear and off
Problem Cause Solution Colored lines appear. The exposure glass or scanning glass is dirty. Clean them. See "Maintaining Your Machine", About this Machine . Copies appear dirty. Image density is too high. Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference . Copies appear dirty. Auto Image Density is not selected. On the control panel, select [Auto Density]. The reverse side of an original image is copied. Image density is too high. Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference . The reverse side of an original image is copied. Auto Image Density is not selected. On the control panel, select [Auto Density]. A shadow appears on copies if you use pasted originals. Image density is too high.
  • Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference .
  • Change the orientation of the original.
  • Put mending tape on the pasted part.
The same copy area is dirty whenever making copies. The exposure glass, scanning glass, or ADF is dirty. Clean them. See "Maintaining Your Machine", About This Machine . The same copy area is dirty whenever making copies.
  • The original that has already been printed is scanned.
  • Original Type is set to [Text / Photo], and an original with text and photographs that can hardly be distinguished from each other is loaded.
On the control panel, press [Generation Copy], and then begin copying. Copies are too light. Image density is too light. Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference . Copies are too light. A light copy may result when you use damp or rough grain paper. Use recommended paper only and be sure its storage environment meets the recommended temperature and humidity conditions. For details about recommended paper and the proper way to store it, see "Recommended Paper Sizes and Types" and "Paper Storage", About This Machine . Parts of images are not copied. The original is not set correctly. Set originals correctly. See "Placing Originals", Copy and Document Server Reference . Parts of images are not copied. The correct paper size is not selected. Select the proper paper size. Parts of images are not copied. Even if you place originals in the ADF correctly, margin of a few millimeters on all four sides of the original might not be copied. Use "Create Margin" function to reduce the image of its original size.
For details about missing image area, see "Missing Image Area", Copy and Document Server Reference . images appear only partially. The paper is damp. Use paper that has been stored in the recommended temperature and humidity condition. For details about the proper way to store it, see "Paper Storage", About This Machine . Black lines appear. The exposure glass or scanning glass is dirty. Clean them. See "Maintaining Your Machine", About This Machine . White lines appear. The exposure glass or scanning glass is dirty. Clean them. See "Maintaining Your Machine", About This Machine . White lines appear. The dustproof glass is dirty. Clean the dustproof glass. See "Cleaning the Dustproof Glass", About This Machine . Copies are blank. The original is not set correctly. When using the exposure glass, face the originals down. When using the ADF, face them up. A moir? pattern is produced on copies. Your original has a dot pattern image or many lines. Place the original on the exposure glass at a slight angle. Black spots appear on the copy of a photographic print. Because of high humidity, the photographic print has stuck to the exposure glass. Place the print on the exposure glass in either of the following ways:
  • Place an OHP transparency on the exposure glass, and then place the print on the OHP transparency.
  • Place the print on the exposure glass, and then place two or three sheets of white paper on it. Leave the ADF open when copying.
White stripes appear on the OHP. Fragments of paper are stuck to the OHP. Use a dry cloth to wipe any paper fragments off the back of the OHP. The image on the back side of duplex copies has mottled blank patches or is smudged. Missing patches and smudges are caused by moisture leaking from the paper.
  • Do not install the machine in areas that are susceptible to low temperatures.
  • Use paper that has been stored where temperature and humidity conditions meet the limitations we recommend. For details about the paper storage conditions we recommend, see "Paper Storage", About This Machine .
  • Install the Optional anti-humidity heater. For details about the anti-humidity heater, contact your service representative.
When You Cannot Make Clear Copies
1helpful
Konika Minolta Copier prints half dark pages
If it is only causing an image problem when you copy and not when you print, then there is something wrong with the optics under the glass. Check and see if you have any mirrors out of place or if the scanner looks crooked. If you have the machine set up to scan try and scan to SMB or email to see if it still has the problem. If everything looks correct under the glass and scans to SMB and email look bad like the copies, you may have a bad CCD assembly, or a bad board.
1helpful
Sharp copier, not producing clean copies
Check the fuser roller if it still has faint prints on the roller then your getting a shadow image in your prints,. Could be a bad fuser roller replace it
1helpful
Print stops printing "blue" after first 1/3 of image is printed.
A good self test page indicates that the printer and print cartridges are functioning properly. Something else is causing the print quality problem
Here is a document on this problem:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&product=1155996&docname=c00211601
Here are the drivers and software: (select your OS)
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&docname=c00211601&product=1155996&
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Printer won't print
Printing on stand alone has a big difference when printing from pc.... try using the kodak website for this issue www.kodak.com/go/itg and use "image quality and blank page" for subclass
MFC-9840 prints vertical stripe ~2" from right edge on all color printouts
The first thing i would try to do is clean the corona wire on the drum unit. It might also be a faulty magenta cartridge.
k24674
ADMIN Andrew
ADMIN Andrew
