Magic Chef Chest Freezer MCCF5WBX Logo
James Smith Posted on Oct 01, 2014
There is a alarme light showing on my chest frezzer what dose it mean
What does alarm light mean on scandinova chest freezer
its not running correctly- getting warmer-ajar door
Jun 12, 2019 • Freezers
What does the red warning light by the triangle mean on a blomberg
Under normal operating conditions, the internal
temperature of the freezer will ensure the longterm
conservation of the stored food.
When such temperature rises above a certain
level (-12 °C), the appliance will trigger an
acoustic and light alarm. The light alarm is a
blink red light (Red Alarm Indicator Light), while
the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing
the Acoustic Signal Stop Switch once.
When switching on the freezer for the first
time, the Red Alarm Indicator Light will
blink until the internal temperature has reached
a level required for the safe conservation of frozen
food.
Dado
There are 3 lights on the front of the Zanussi Freezone. The green one on the left doesn't light up. What does that indicate? The red light on the right is on constantly. Does this mean that the freezer is...
Starting the Appliance
Insert the plug into the wall socket. The green pilot light will illuminate to show that the appliance is switched on. The red alarm light will also illuminate until the freezer reaches the correct temperature.
Alarm Light
The red alarm light will illuminate when the temperature in the freezer is higher than the thermostat setting. This alarm light will illuminate if:
- The appliance has just been started.
- Fresh food has been put in the freezer.
- The lid has been left open, opened frequently or open for too long.
The red light will go out when the freezer has returned to the correct temperature
Dado
The light is on but the freezer is not cooling
You did not specify which lights are on?
  • The green pilot light will illuminate to show that the appliance is switched on.
  • The red alarm light will also illuminate until the freezer
  • If you press the SUPER button than you start fast freeze function and yellow light will illuminate.
I assume that the freezer is on and the green light is illuminated. This means that the freezer is on and energized.
Also, if freezer does not cooling, means that did not achieve the set temperature should be illuminated the red light (alarm).
Set the thermostat for example in position 4th and after that compressor should be start.
If compressor running but not cooling, defective is the system which circulates gas.
If compressor does not start, then is faulty thermostat, compressor or the wiring.
Dado
Dc518 wey will not freeze top was cool but not now what can i do takes r134-a
Check the condenser is clean. If the outside of the chest isn't warm and you can hear the compressor running. It's short of gas.
I need an online manual for proline freezer CF6 37P see drection for temperture control
there a alarme light showing on my chest frezzer what dose it mean
2helpful
Proline chest freezer - the alarm light has come on. What does this mean and what needs to be done to get things back to normal. Thanks
hi this normally means the temperature got too high, could have a cooling problem or somebody had the door open too long.
Sean
Mar 26, 2011 • Freezers
I just moved into a home with a kenmore chest freezer. This is a real dumb question, but which symbol means on. Should the circle be showing for "on" or should the line be showing for "on"?
Some freezer models feature a temperature
monitor that provides an audible
alarm. The temperature monitor alarm is
located near the temperature control
The alarm sounds if the temperature in
the freezer rises 10° F (12° C) or more
above normal for selected setting. Alarm
may sound if temperature control dial is
turned to a much colder setting or if a
large amount of unfrozen food is added at
one time. Alarm is controlled by a three
position switch
0 = OFF prevents alarm from sounding
when freezer is warm, such as during
initial start-up or defrosting.
• ✓ = TEST sounds alarm regardless of
temperature. Alarm system should be
tested at least once a month.
1 = ON is proper setting for normal
freezer use. Return switch to 1 after
defrosting.
Top Magic Chef Freezers Experts
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Magic Chef Freezer Expert? Answer questions, earn points and help others
