Question about Estate Dryers
Dryer takes 3 cycles to dry clothes
Dries clothes but towels take 3 cycles heating element seems to be working maybe a thermostat issue?
Posted by Don on
Lawrence Oravetz
  • Estate Master
  • 10,548 Answers
Air flow blockage will shut the thermostat down early. You may need to clean out the lint filter holder with a vacuum cleaner or a bent coat hanger. Look inside the dryer vent hose. It probably has a load of lint dust in it. A thorough cleaning is in order.
Posted on Oct 01, 2014
5 Related Answers
Anonymous
  • 57 Answers
SOURCE: dryer heats up but does not dry clothes
first take the venting off the back of the dryer and dry a load if dryes normal replace venting if takes a long time to dry have a repair man clean the dryer
Posted on Jun 24, 2008
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: roper clothes dryer not drying clothes
Please take a look at the following link. In particular, the first major paragraph where it discusses proper ventilation:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
I know the link is for a dryer that no longer heats, but if a dryer is left in a condition where it is starved for air, the heating circuits will actually over-heat and eventually fail. You need to ask yourself when was the last time you inspected or cleaned the dryer exhaust ventilation. If you can't remember, or if you've never cleaned anything before, it may be a good time to do so. Most dryer heat related problems are caused by poor ventilation and lack of cleaning. I recommend that you clean the dryer ducting twice a year. That's once in the spring, and once again in the fall. It is also important to note that the SHORTER and STRAIGHTER the exhaust vent line is, the BETTER. The more bends and kinks that you put in the dryer exhaust, the more resistance you create for the dyrer blower, and the more potential choke points you create where lint can accumulate and clog. Not to mention, this can also cause a fire hazard and/or a habitat for rodents.
Follow the recommended advice and try drying a load of clothes with the vent hose removed, first. If your clothes dry faster like they should, you may have an exhaust clog somewhere. If your clothes still aren't drying correctly, inspect the interior blower fan housing for obstructions. This is all explained in the link provided.
If you attempt these preliminary measures and still have problems, please let me know. I hope you find this information helpful.
Posted on Sep 04, 2008
Charles Caldwell
  • 66 Answers
SOURCE: UN-ending Auto dry cycle
This is caused by the dryer vent being blocked and not allowing the moist air to be removed from the dryer. To confirm this. Dry a load of close in a timed dry setting. Set the time on a specific time and then start the dryer. Wait for about 5 min. See if the timer has moved. If it has then the problem is not the timer. It is the exhaust vent being plugged up somewhere. Moisture how the auto dry setting works. The dryer sences moisture and runs longer to dry your clothes. With the dryer exhaust vent blocked, wet moist air is comming back into the dryer and fooling the sensor into believing the close are not dry and runs for a very long time. It is not uncommon for this problem to cause a dryer to never shut off. Your dryer exhaust vent is plugged up with lint somewhere.
Posted on Nov 13, 2008
Macmarkus
Mark MacDonald
  • 2605 Answers
SOURCE: why does my dryer take so long to dry my clothes
It sounds to me like a problem with either a) poor venting/obsruction of some kind...possibly kinked hose ? or b) the blower wheel in the unit responsible for moving the air is spinning freely on the motor shaft.
Check your venting first, insure you have a strong flow of air where the unit exhaust's outside. if yes, good. if no...pull the vent off from the back of the dryer itself and make sure you get good air flow (exhaust) there. If you don't get any or very little flow with the vent off, chances are likely you have a broken blower wheel.
These are the most common and likely sources of a dryer that actually heats, but takes a long time to dry garments.
(Another possible cause that goes unnoticed often, is no issue with the dryer at all, but the washer not spinning properly,(kinked drain) be it mechanical or overloading...check that too).
hope that helps
good luck
Posted on Sep 30, 2009
Anonymous
  • 612 Answers
SOURCE: bosch axxis wtl 5410 dryer takes too long to dry.
You should have a cycling thermostat. this is most likely bad or your dryer vent may be clogged. Something is cutting the heat off before it gets hot enough. Both these cause this problem.
Posted on Nov 17, 2009
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
My dryer only damp dries. Cannot dry towels. seems to take forever to dry anything
Hello there and thank you for choosing fixya
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it. To determine if the heating element is burned out, watch the part testing video at the bottom of this page. Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician. Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Jun 29, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
Kenmore dryer...model # 1108262101 clothes not getting dry...normal dries better than perm press but still not as good as before....where do I begin? Thanks, Mary
Hi lkyldy31...
Your dryer is acting like it has a Clogged Vent
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
This is a Free answer, Please rate me.
Apr 22, 2011 | Kenmore Dryers
GE Dryer model DDE8509R0MWW is getting warm but not hot, takes forever for clothes to dry :(
Check the ductwork for excess lint, kinks, bird nests (yes) or anything else that would restrict the air flow. There is a lazy man's shortcut for electric dryers ONLY: Disconnect the dryer vent and run a load of damp clothes... if the dryer dries the load in normal time, the duct is clogged or kinked. If it doesn't, it's something wrong inside the dryer.
The most common reason for your problem is the cycling thermostat. This is cheap and relatively easy to fix. GE cycling thermostats require turning OFF the power and removing the front of the dryer. It's located on the blower housing. Two wires, two screws. If you have an ohm meter, a good one will read zero ohms.
http://www.repairclinic.com/PartDetail/Cycling-Thermostat/276447?modelNumber=DDE8509RCMWW
The other possibility is the heater element. GE has a dual element. If half of this heater breaks, it takes a long time to dry towels and jeans. Incredibly, GE gets about $200 for these because you can't replace only the heating coil (which was only about $30)... you have to buy the whole unit. This requires removal of the drum. Not impossible for do-it-yourselfers, but it's a challenge for first timers.
Good luck.
Mar 03, 2011 | Dryers
Whirlpool dryer wed5200tq0: I have to run cycle
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
****(((Please disregard step three if this is a GAS dryer)))
Aug 21, 2009 | Whirlpool Dryers
Not drying properly, no heat
1. Venting
2. Thermostat
3. Heating element
Aug 06, 2009 | Dryers
My dryer takes 2 to 3 cycles to dry my clothes.
Check the following areas to combat this issue. in most cases, this will be a Venting issue.
1. Venting
2. Thermostat
3. Heating element
Jun 21, 2009 | Whirlpool LER4634J Electric Dryer
Dryer won't heat up to dry the clothes the heating element works
Check the following to address this issue--
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
2. Thermostat
3. Heating element
Jun 03, 2009 | Kenmore Dryers
Not heating properly, many cycles to dry loads
1. Venting
2. Thermostat
3. Heating element
Jun 02, 2009 | Maytag SDG3606A Gas Dryer
LG Dryer takes way long to dry
Let's work together to get to the bottom of this problem. begin with these thoughts
Vent
Heating element
Internal ductwork
Cycling thermostat
May 29, 2009 | LG DLE5977 Stainless Steel Electric Dryer
Dryers Logo
119 people viewed this question
Top Estate Dryers Experts
Mike
Marvin
Marvin
Paul Carew
Are you an Estate Dryer Expert? Answer questions, earn points and help others
