SOURCE: I have a SONY 50in LCD and a light spot about 8in
This is a bad light engine. Refer to a local technician for replacement cost and repair as this is not a cunsomer repair item
SOURCE: my Philips 50in flat screen when turned on goes to
don't open the tv because they have a problem inside your tv and after that if you want .................................................................................later.
SOURCE: Hi we have a 42in philips matchline flat tv. When ...
mine is doing the same.... any solution to fix this problem?
SOURCE: i have a 50in philips.
could be a bad ribbon cable conection to the 'X' circuit boards along the bottom of the display panel
SOURCE: Black spots blocking picture on plasma TV
Main board is likely the issue or worst case is a defective main screen called a display panel. Voltage checks will not usually help with this type of problem since it will likely have to be traced with a scope.
3-5 years is average life on this type of set and Philips is known for parts at that age becoming unavailable............
