Reverse doesn't work at all and to turn forward speeds off you have to turn past off to a reverse speed to stop prop. Then you can turn back to off. Then to start forward you have to turn up to number two before forward starts.
SOURCE: motor on ly runs on high speed
Hello rhett700, you have crossed a wire connection on the switch or your reostat is shorted/bypassed. If need be contact 'www.minnkotamotors.com/index.asp' ask for ext#406 ask for Dave. Have your model & serial # on hand. He is a good guy. Merry Christmas.
SOURCE: MinnKota Endura 50 Runs only in high speed in forward and reverse
the coil pack is likely bad especially since you changed the switch. call minkota and get the bench tast info (very simple) and then order and replace the coil pack about 26 dollars. be very careful how you put the magnet assembly back together and mark the position of the case on the outside before disassembly. order a new seal kit and use locktite on the shaft again when reassemling to seal the shaft tube for water. dont run motor uout of the water much as it uses the water to cool the shaft and you can damage the seals. good luck.
SOURCE: I have 5 forward and 3 reverse speeds. My motor
Same problem. Bought motor used. Can't figure it out.
SOURCE: My Johnson Escape boat w/ Minn Kota engine stopped running
I've had the same problem. It steams from the control panel. I took and ran a seprate ground wire directly to the motor. This is simple to do and takes 15 minutes. Starting in the battery compartment feed cable into the split-loom and continue feeding until reaching the control panel. Pull an extra 5 foot of cable and open dry hatch in rear by motor feed cable around and out to motor connections., Good time to replace rotary switch and circuit breaker. These also are trouble-some parts.
