Tablets & eReaders Logo
A
Anonymous Posted on Sep 30, 2014
Netflix for iPad ios 5.1.1
I pad 1st gen iOS 5.1.1 trying to find Netflix app to work on that iOS version.
Jesse Scarborough
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 20 Answers
  • Posted on Oct 01, 2014
Jesse Scarborough
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
20
Questions
0
Helped
4116
Points
23
Unfortunately, Netflix only makes an iPad app for iOS 6 and later. You will have to get a newer iPad if you really, really want to watch Netflix on it, because your iPad cannot be upgraded to iOS 6.
2helpful
2answers
How do I download free Netflix app that is compatible with apple ipad1 first generation iOS 5.1?
install netflix on ipad first gen.:
first make sure your iPad 1st. gen is on iOS 5.1.1 !
It is possible, a bit tricky, but possible. First, you'll need to download the Netflix app through iTunes on your computer, this will make it show up as "purchased" in your library. After that, open up the App Store on your iPad 1 and go to the 'purchased' tab. When you try to install it this way it will tell you that you need iOS 6 or higher, but will also ask if you would like to download an older version of the app. then click on download.
- again step by step:
1) Open up iTunes on your computer
2) Go to Store (left hand column) ->iTunes Store
3) Search for Netflix; - download the app
4) then open App Store on your iPad
5) Click on 'Purchased'
- you will have to install NetFlix by clicking on it as usual.
App Store will ask you: "Download an older version of this app. The current version requires iOS 6.0 or later, but you can download the last compatible version.",
then click on Download and it should finally work.
download-free-netflix-app-compatible-ucocffsbdgqp14shduy2nfxr-3-0.jpg download-free-netflix-app-compatible-ucocffsbdgqp14shduy2nfxr-3-2.jpg download-free-netflix-app-compatible-ucocffsbdgqp14shduy2nfxr-3-5.jpg
How can i get netflix ios 5.1.1 for ipad.
Netflix for iPad is only compatible with iOS 6.0 or later, so you'll need to update iOS to download the current version of the Netflix app from the App Store. This can be done by opening Settings, selecting General, then tapping Software Update, or by connecting the iPad to your computer and opening iTunes, which should prompt automatically if an update is available for iOS.
How can To download iOS 6 to a 1st gen iPad?
simply, you cannot!
For the iPad first generation (A1219) to update is only possible with connecting the device to iTunes on a computer if you don't have iOS 5 on it.
- this model supports only iOS 5
- NO iOS 6/7/8 !
download-ios-6-1st-gen-ipad-qrl052hdp2kg0kvuqxssgusw-2-0.jpg download-ios-6-1st-gen-ipad-qrl052hdp2kg0kvuqxssgusw-2-2.jpg download-ios-6-1st-gen-ipad-qrl052hdp2kg0kvuqxssgusw-2-9.jpg
Download ios for ipad
no, you cannot.
on a 1.gen. pad it is impossible to install iOS6:
this model supports only iOS 5 !
- NO iOS 6/7/8
- the processor is too slow....
For the iPad first generation (A1219) before iOS 5 to update is only possible with connecting the device to iTunes on a computer. Plug it into your computer and open up itunes under devices click on your ipad and then click on check for update.
- but this model supports only iOS 5
iPad Wi Fi Original 1st Gen 16 32 64 GB Specs iPad Original A1219 MB292LL...
download-ios-ipad-ucocffsbdgqp14shduy2nfxr-3-0.jpg download-ios-ipad-ucocffsbdgqp14shduy2nfxr-3-5.jpg
Download iOS 6
- NO iOS 6/7/8
For the iPad first generation (A1219) before iOS 5 to update to iOS 5 is only possible with connecting the device to iTunes on a computer. Plug it into your computer and open up itunes under devices click on your ipad and then click on check for update.
- NO iOS 6/7/8 !
download-ios-6-ankdbq4aprjqdzyss1inbix3-4-0.jpg download-ios-6-ankdbq4aprjqdzyss1inbix3-4-2.jpg download-ios-6-ankdbq4aprjqdzyss1inbix3-4-5.jpg
How do I download iOS 6.0 on my iPad first generation
you cannot!
- NO iOS 6/7/8
download-ios-6-0-ipad-first-generation-ucocffsbdgqp14shduy2nfxr-3-0.jpg download-ios-6-0-ipad-first-generation-ucocffsbdgqp14shduy2nfxr-3-2.jpg download-ios-6-0-ipad-first-generation-ucocffsbdgqp14shduy2nfxr-3-9.jpg
IOS 6 for iPad
on a 1.gen. pad it is impossible to install iOS6!
- NO iOS 6/7/8
- NO iOS 6/7/8 !
ios-6-ipad-ankdbq4aprjqdzyss1inbix3-4-0.jpg ios-6-ipad-ankdbq4aprjqdzyss1inbix3-4-2.jpg ios-6-ipad-ankdbq4aprjqdzyss1inbix3-4-5.jpg
3helpful
How to upgrade
1st gen iPad are stuck at iOS 4 keep a good archive of your apps, you won't be able to replace them easily
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
