Cars & Trucks Logo
A
Anonymous Posted on Sep 30, 2014
How do i change turn signal switch - Cars & Trucks
how do i change turn signal switch
Lawrence Oravetz
Level 3:
  • Cars & Trucks Master 10,558 Answers
  • Posted on Oct 01, 2014
Lawrence Oravetz
Level 3:
Answers
10558
Questions
Helped
2699927
Points
29284
Not enough info. What kind of car? Is there an air bag in the steering wheel? Does the wheel tilt? You'll need special removal tools to get the wheel off and you'll have to find the special connector to unplug if the wheel has an air bag in it.
How do you locate and test flasher relay on a 2006 Chevy Equinox? Turn signals and hazards stopped working after changing audio system. Fuses test good. Thank you, Mike
Did you change any wiring , tap into any wiring ? There is no flasher relay on your vehicle . It controlled by the BCM !
Turn Signal/Hazard Lamps
The body control module (BCM) is responsible for controlling the turn signals and hazard lamps. When the turn signal switch is placed in either the left turn or right turn position, the BCM receives a signal from the turn signal switch. The BCM then sends an on-off voltage signal to either the left or right turn signals and their instrument panel cluster (IPC) indicator. When the hazard switch is pressed, the BCM receives a signal from the hazard switch. The BCM then will send an on-off voltage signal to all the turn signal lamps. All the turn signal lamps will flash including both IPC turn signal indicators.
Your best bet , take it to a qualified repair ! We on here have no clue what you did . On this newer vehicles ,if you know nothing about automotive electronics you really should take to a professional
1helpful
Why does turn signal sound all the time unless the br(ake) is pressed?
Taryn, sounds like a faulty turn signal switch, or multi function switch is defective. Check all the bulbs and sockets first for damage wires, burnt wires or bulb socket, cheapest part to change besides bulbs would be the signal flasher or the signal relay if you want to go this route. Below are trouble shooting links you can read or watch.
press the helpful button and follow me on fixya for more tips
Turn Signal Switch May Fail and Cause Clicking Noise Chevrolet Tahoe...
How To Change Turn Signal Wiper Control Switch On Ford Lincoln Or Mercury
How to Replace Your Turn Signal Relay in Lincoln Navigator eHow
Blinker light flasher change out on 2003 Ford Expedition
How to change turn signal switch on 1994 Honda passport
Hey dean how's it going ? here is video on how to do it ! It's not the same vehicle but should be close ! How To Install Replace Headlight Turn Signal Switch Honda Accord Prelude...
4helpful
2answers
95' Buick regal, 3rd brake light works, tail lights work, turn signals work, stoplight switch seems to work ie 3rd brake light working, fuse is ok, changed bulbs, but no rear brake lights.
If the third brake light works and the regular ones don't, it is most likely a bad turn signal (multifunction) switch. The switch is able to kill the brakes lights to run the turn signals, and in rare circumstances does this. I've seen it several times. It could also be wiring, especially near the turn signal switch, but it is usually the switch.
1998 Cavalier rear turn signal doesn't work
The turn signal switches are known to go bad, try to use the turn signal switch and jiggle the lever after clicking to the left turn. Replace signal switch assembly.
Changing turn-signal switch
hi,first remove the neg. battery cable,remove air bag with care,then remove steering wheel,combi..swicth can remove,ty
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
