Question about Jenn-Air JSD2789GES Side by Side Refrigerator
<!-- from fixya rte -->Freezer door not tie enough - Jenn-Air JSD2789GES Side by Side Refrigerator
ICE BUILD UP IN A MAYTAG MODEL MZF34X16DW UPRIGHT FREEZER
I have had a few of these, and others of the same ilk.
Your problem should be air leakage into the machine.
Take a thicker piece of paper, not cardboard, and try to slide it around the gasket where the door gasket contacts the front of the freezer.
The gasket should be firm enough to prevent the paper from sliding. Wherever you can move the paper, you could have a air leak.
Most of these have no adjustment in the latch to tighten the door. Sometimes a new gasket will solve the problem, sometime a new door will.
P.S. Twice I have tied a new freezer to a refrigerator dolly to move it and have accidentally warped the door, and they cannot be straightened. :-(
God bless your efforts.
Jul 07, 2017 | Maytag Freezers
Plastic door shelves fall out
Try small cable ties if they sit on pegs sticking out you can then cut the ties for removal.
Aug 26, 2014 | GE 21 cu ft Top-Freezer Refrigerator White...
I Have A Freezer Model Fuf17svrww.the Door Open Light Control Is On And Sounds and the door is completely close
Check the door switch is being closed when the door closes. The door may have dropped just enough to allow the switch not to be activated by the edge of the door.
Apr 18, 2014 | GE FUF17SVRWW Upright Freezer
Water leaking from inside the freezer
if the bottome of the freezer floor is frozen then the most common cause is that the defrost drain is cloged, the back wall will mostlikley need to be removed and defrosted, then i use hot water & a long zip tie to make sure the drain is clear, don't use anything too hard as to punch a hole in a drain hose.
May 24, 2010 | Samsung RS2630SH Side by Side Refrigerator
Food is not completely freezing in spots
This is a symptom of air leaking into the freezer. The most common place is around the door. Check the door really good to make sure something is not obstructing it from closing all the way, it may be closing enough to satisfy the ajar alarm but not enough for a bit of moisture to sneak in. Look for tears or breaks in the seal. If you put a bright flashlight inside the freezer and close the door, turn off the lights in the room you may find a leak that way.
May 03, 2010 | Electrolux 21.0 Cu. Ft. Upright Freezer -...
Freezer & fridge not cold enough, frost in freezer
Refrigerator or freezer is not cold enough
* Check the temperature setting
* Assure that there is enough room for air flow in the refrigerator or freezer
* Check for air flow restrictions in vents
* Test the temperature control
* Clean the condensor coils
* Check the door seals
* Test the door switch
* Test defrost heater
* Test defrost timer
* Test evaporator fan
* Check for a clogged drain tube
* Check for refrigerant leak
Mar 31, 2010 | Whirlpool 21.0 Cu. Ft. Frost-Free...
Evaporator fans do not come on, why would evaporator is not cool enough?
There are three main reasons the fans would not come on.
1: A bad door switch. There are switches on the top part of door frame. They turn fans off when door is opened to prevent warm air from being drawn into unit when door is open. If a switch goes bad the fans will never turn on.
2: Refrigeration problem. The fans are tied into a temperature switch called a fan delay. The fans will not come on until the coil is well below freezing. This is to prevent water spray after a defrost. If unit is low on gas or has any other cooling issue the fans will not come on.
3: Bad fan delay switch. If the fan delay switch becomes "stuck open" the fans will not be energized.
Feel the back of your evaporator coil, if it is very cold and frosted you probably have a bad fan switch, or a bad door switch. ;)
Oct 10, 2009 | True 49 cu. ft. / 1388 liter Commercial...
I have a side by side GE Monogram. When closing
the refrigerator should be leaning back enough to allow it to reclose. there are hieght adjusters behind the grill on front
Jun 12, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Door to refrigerator will not close properly.
The refrigerator door seal is being broken when you open the freezer door? Sounds like the rubber magnetic strip needs to be replaced on the refrig. door, they wear out after a number of years.
Oct 28, 2017 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Jenn-Air JSD2789GES Side by Side Refrigerator Logo
Top Jenn-Air Refrigerators Experts
john h
Sheldon Dedek
Marvin
Marvin
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
