Question about Car Audio & Video
What is the difference between 12" Infinity-Watkins Dual-Drive woofer and Infinity Watkins Dual Voice Coil 12" woofer #85140178 for Quantum 2,3,4,5 QLS. Can I use Infinity Watkins Dual Voice Coil 12"
What is the difference between 12" Infinity-Watkins Dual-Drive woofer and Infinity Watkins Dual Voice Coil 12" woofer #85140178 for Quantum 2,3,4,5 QLS. Can I use Infinity Watkins Dual Voice Coil 12" woofer for my Infinity quantum 4 speaker. Is Dual Voice Coil 12" woofer with foam around ?
Mike Murphy
Watkins woofers are not a normal dual voice coil woofer. They are designed to be used with a special crossover that when one coil starts rolling off due to rising impedance the other takes over to extend the bass frequencies lower. What is the difference between 12
Posted on Jul 09, 2020
5 Related Answers
simplemitch
Mitch
  • 752 Answers
SOURCE: 2 dual voice coil 12" 1200 watts subs
Are they dual 2 ohm or dual 4 ohm?
Posted on Sep 22, 2007
Cerfer39
Greg Stokes
  • 709 Answers
SOURCE: aw 1251 audiobahn 400w. woofer
Yes, wire the Voice coils in series. This will give you at least 4 ohms.
Amp+ to VC1+
VC1- to VC2+
VC2- to Amp-
Posted on Nov 25, 2007
Anonymous
SOURCE: speaker wiring
hi mat
you should have four terminals two plain and two with dots
to get the best power cut two inches off good speker wire
tear apart now place one wire from
plan black to red with white dot then
plain red to black with white dot
this is how set then up with my directed 1100d mono amp .. very loud at half gain
well hope this helps.............. ..benjaminsarmy..
Posted on Mar 23, 2009
Anonymous
  • 5 Answers
SOURCE: how can i check if one voice coil is burned out on
hi there, looking from the back with the S the right way round, put a meter across the two terminals on the left + and - to check the first coil, then same on the right, if it shows o/c then youll know which one if duff!
hope this helps
Posted on Sep 21, 2010
logosc75
Larry Spears
  • 625 Answers
SOURCE: i cannot find a diagram
I will assume that you mean four posts total and not four on each side. It's a dual voice coil and you will need a jumper. Take a small strip of speaker wire and connect the positve and negative of one coil together. Take a close look, there is a dot on one positive and a dot on one negative. Jump these two together. Now wire the other positive and negative to the amp's positive and negative.
Posted on May 24, 2011
I need to wire 3 woofers but 2 are dual voice coil and one is single voice coil
sure, if you wish to wire them all together, wire the first dual voice coil subs first voice coil negative to 2nd voice coil positive, second voice coil negative to single voice coil sub positive, and single voice coil negative to 2nd dual voice coil subs 1st voice coil positve (again with the second dual voice coil sub, run the first voice coil negative to the 2nd voice coil positve) your speaker leads will be attatched to first dual voice coils 1st voice coil positive, and 2nd dual voice coils 2nd voice coil negative)
Apr 01, 2013 | Kenwood KAC-8104D - 1000 Watts Class D...
Can i power 2 12 subs a rockford punch z and a xplode with this amp i found all this **** in my garage and i need to know if it will power all this
First of all. Using two different kinds of sub woofers, is not an option, as these two sub woofers have different specifications and you should never mix sub woofers. Now the better choice from the 2, would probably be the Rockford. (cant be sure without knowing the models, power handling is also a factor in how well either of the sub woofers will play, but Rockford as a rule makes better sub woofers than Sony does) In my opinion, both the sub woofers deserve a better amplifier than what Boss has to offer. However to connect either of these sub woofers, you would need to determine how many voice coils it has and how many OHM the voice coil/s are. If it is a DVC (dual voice coil) and each voice coil is 4 OHM or 2 OHM, then you can connect one voice coil to one channel of the amplifier and the other voice coil to the other channel of the amplifier. If it is a DVC 2OHM you can also connect it wired in Series/Series to give a 4OHM load and should be connected to the BRIDGE dedicated speaker outputs of your amplifier. If it is a SVC (single voice coil) and it is 4 OHM, then you can connect the sub woofer to the designated speaker outputs of your amplifier that states BRIDGE. DO NOT run the amplifier in BRIDGE mode at 2 OHM as this will probably damage the amplifier. dreamsystems
Feb 18, 2011 | Boss Blade BL700 2-Channel Amp - 300W...
WHAT KIND OF AMP SHOULD I USE ON SOME ICBM-5612
You can use any type of amp as long it can drive at least 1000 watts and it 2 ohm, 4 ohm or 8 ohm stable.Here is the specs on the woofer:
  • 12" High Performance Subwoofer
  • Rubber Seal Gasket
  • High Temperature 2" 4 Layer Voice Coil
  • Air Vented Aluminum Fomer
  • Dual Voice Coil ( 4 ohm + 4 ohm)
  • Large Foam Edge Surround
  • Bumped Plated For Maximum Excursion
  • Excellent For Sealed and Bandpass Enclosures
  • 70 Oz Magnet Structure
  • 1000 Watts Max
  • Frequency Response: 25Hz-800 Hz
  • 2 Ohm / 4 Ohm/ 8 Ohm Operation
  • Screw Block Terminal
Also check this website for how to wire it to 2, 4 or 8 ohms: http://www.bcae1.com/spkrmlti.htm
Dec 26, 2009 | Performance Teknique ICBM-5612 Car...
I have 2 positives and 2 negatives on back of my alphasonik sub, do i connect amp to one side or both sides?
Hello gaz69,
Your PSW815 has 2 ohm dual voice coils allowing you to better match the impedance to your amp. Each voice coil is 2 ohms. If you wire them in parallel (both +'s together and both -'s together and then to the amp terminals), the sub presents a 1 ohm load which is too low for most amps. Wiring the voice coils in series (one + to the other - and the remaining + and - to the amp terminals) results in a 4 ohm load.
This link shows the wiring diagram for both options. If you know for sure that your amp is 1 ohm stable, use Wiring Option #1. If the amp is not 1 ohm stable, use Wiring Option #2.
Hope this helps.
Aug 09, 2009 | Alphasonik PSW815 Car Subwoofer
Ok, I have a pair of infinity dual voice coil 12" subs, and a pair of audiobahn quad voice coil 12" subs. Boths sets of speakers can handle 450w. Which set of 12's would be best to hook up to this amp, and...
i recomend you just use the best single woofer in a well built box and that will give you better sound at lower gain volumes it sounds like you have too much junk laying around but to get good bass run your sub at 2 ohms if the amp is stable at that impedence
Dec 16, 2008 | Phoenix Gold Xenon-200.4 Car Audio...
Infinity 1600a cuts out wit real low bass when turned up load
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage drops below ~11 volts on either terminal when you drive the amp hard, you need to check the wiring feeding whichever line is dropping too low.
Nov 16, 2008 | Infinity Reference 1600a Car Audio...
Alpine mrd m500 amp is not pushing my 12 in infinity sub
If you have a dual voice coil sub, make sure that you have the positive and negative terminals connected properly. If you have ONE of the coils wired backwards, it will cause the speaker to produce little or no sound.
Have you set the gains properly?
Are you sure the amplifier is receiving a strong signal from the head unit?
Have you tried it with a different speaker?
Jul 19, 2008 | Alpine MRD-M1000 Car Audio Amplifier
Car Audio & Video Logo
362 people viewed this question
Top Car Audio & Video Experts
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
