Question about Gaggia Titanium Espresso Machine
Can't get rid of ventilate message on titanium plus machine
I have tried the solutions suggested on this forum (switch off, release steam...) but no steam releases. I just get a message to close steam valve and the ventilate message re-appears.
Posted by gill854 on
Ernest R
    President:
  • 1,618 Answers
Try this, after opening hot water valve, push the knob in when it asks for ventilate. If that works then contact your nearest gaggia distrubutor and ask for a new stainless steel steam valve assembly.
Posted on Jul 10, 2009
Hello I have a problem with y machine. I have got a message "Ventilate", and i have pushed the button 26, but nothing happens. What to do?
You need to push the hot water button on the machine panel to allow water to run out of the steam wand. After a few seconds the machines ventilate message should clear.
Jun 04, 2010 | Gaggia Titanium Espresso Machine
Ventilate problem on gaggia titanium coffee
You need to push the hot water button on the machines panel to allow water to run out of the steam wand. After a few seconds the machines ventilate message should clear.
May 27, 2010 | Gaggia Titanium Espresso Machine
Keep getting ventilate message - won't ventilate and cannot operate steam or grinder w/ ventilate message
Try this run the hot water cycle for a few seconds, it that works, try steaming if you get the message again clear it by running the hot water cycle and then go to steaming, this time push in on the knob after you open it, it that works, then the tap rod or the valve assembly needs to be replaced.
May 01, 2010 | Gaggia Titanium Espresso Machine
MACHINE GETS HOT ON TOP RIGHT HAND SIDE.TRYING TO LOSE VENTILATE
The top right hand side can get hot if you have the cup warmer switched on.
I am finding that the steam boilers are starting to block up and the steam lines are getting scaled up.
If you have access to compressed air,undo the boiler and lines and blow them out.
I have had coffee jammed in the inlet of the flow meter,blowing through it will be a good test.
Good luck
Mar 21, 2010 | Gaggia Titanium Espresso Machine
Gaggia Titanium - lack of water/steam!
I have a Gaggia Titanium and the steam valve is leaking can I get repair parts for it
Mar 12, 2010 | Gaggia Titanium Espresso Machine
Ventilate message
Press the hot water button and allow water to flow from the steam arm until ventilate disappears and warming up appears on the display.
Ventilate after descale is normal.
Feb 22, 2010 | Gaggia Titanium Espresso Machine
Gaggia titanium machine, is Ventilate problem connected to leak??
the steam valve is most likly plugged with sacale or such have you decaled the machine latly may want to start there
Dec 17, 2009 | Gaggia Titanium Espresso Machine
Ventilate will not drop from menu ventilate...what to do..how to get rid og msg
Open hot water valve, for a few seconds, water will stream out and pump will engage to vent out water circuit.
May 30, 2009 | Gaggia Titanium Espresso Machine
Ventilate error
Try this, when the message comes up press in on the steam knob, if that works and steam is released, then the tap rod on the steam valve has a problem, contact nearest dealer for new part or send it in for repair(ask for new style stainless steel valve).
Mar 27, 2009 | Gaggia Titanium Espresso Machine
Titanium ventilate issues
Remove the milk frother,checked to see if it is blocked.
This can cause the machine not to ventilate correctly.
They tend to block with old hard milk.
Aug 26, 2008 | Gaggia Titanium Espresso Machine
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
1,858 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Paul Bade
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
