Question about Worx WG500 All-In-One Vac Mulcher Blower, Vacuum and Mulcher
Used it once in early spring and it was fine. Now I try to use it this fall and I plug it in and I have nothing - extension cord works on other equipment, but when I turn on the blower/vac, nothing happens. Any thoughts?
Try cleaning the connection prongs on the leaf blower..some times corrosion builds up when not in use..also if you have a multi meter and know how to check continuity you can check the run switch...just use something like tape to hold the switch in the on position..and the with the meter in the ohlms " continuity " position touch the meter wires to the connection prongs..you meter should show continuity if not the switch is not making connection with the power supply..may need cleaned or replaced...if it shows continuity and still Does not work...need to be serviced...
Posted on Oct 02, 2014
May 27, 2013 | Pool & Spa
Oct 11, 2012 | NorStar Meridian 9516 Corded Phone
Jun 09, 2012 | Refrigerators
Dec 24, 2010 | Garmin n?vi 765T Car GPS Receiver
Jun 27, 2010 | Bakers Pride P24S Single Oven
Apr 08, 2010 | Karcher K2.26 Electric Power Washer
Feb 12, 2010 | Hitachi EC12 Portable Electric 2hp Air...
Apr 24, 2009 | Makita DCS6401 20 20",64cc Chainsaw 2...
Jan 03, 2009 | Bosch PB10-CD Radio/CD Boombox
Apr 27, 2008 | Lands Phones
307 people viewed this question
