Gbc HeatSeal Ultima 65 Laminating System Logo
A
Anonymous Posted on Sep 30, 2014
When using machine the laminator changes direction to backwards rolling and wraps around the first roll (sometimes melting). Any help?
scott westin
Level 1:
New Friend:
  • Contributor 33 Answers
  • Posted on Oct 02, 2015
scott westin
Contributor
Level 1:
New Friend:
Answers
33
Questions
0
Helped
56473
Points
52
Your key panel membrane is going bad, very simple to replace.
Westco Laminating Svcs, 405-324-6092
1 Related Answer
Anonymous
  • Posted on Nov 16, 2011
SOURCE: Our heat seal laminator is
DO YOU HAVE THE DULL SIDE MEETING TOGETHER AND GOING THRU THE MACHINE
SircleLam Eclipse 27 - 27" Roll Laminator isn't rolling?
Question edited for clarity (what it is)'.
Question moved from Washing Machines category, to one of our SircleLam categories.
You paid $2,600 for a laminator!
Contact them direct Call 1.888.207.6494 and tell them you want it fixed under warranty. If they won't, ask for the reason why it isn't rolling?
Sircle Corp http://www.sirclecorp.com > merchant > Product_Cod...
The SircleLam Eclipse 27 is an easy-to-use and operationally intuitive 27" heated roller roll laminator with mounting capabilities designed with superior ...
Film Gauge: 1.5 - 5 mil
Heating Method: Heated Roller US$2,599.99
No one else appears to have had your issue.
https://www.google.com/search?q=sirclelam+eclipse+27+rollers+not+rolling
1helpful
2answers
Ultima 65 laminator. In loading 2 new rolls of laminate, the bottom roll got wrapped around the bottom roller and is stuck. Is there a way to remove the top roller to get access to the bottom roller?
Yes.
But you'll basically need to dismantle the machine to do this.
At the very least all the covers will need to come off.
You may need to remove one or more of the rollers, although you may get away with loosening the roller/s to gain access between them.?
1helpful
I jammed the laminating machine, so I unscrewed and opened the machine...but now I don't know how to roll out the paper? Please help me find a way to take this out without breaking the machine!
Carefully try to turn the roller one direction and then the next. If they move, you will see the feed direction the paper loaded from. Carefully move the rollers in the opposite direction letting the paper unwind. Do not force the gears. Hopefully the paper is not fused to the rollers.
How do I feed New laminating film through straight? Top roll of new film is wrapping around bottom heat roller
go to youtube and watch the video on GBC ultima65 film loading. sounds like you are not using a threading card to load laminator. Manila File folders work great to load laminators Westco Laminating Svcs 405-324-6092
LAM901 Laminator has no reverse. Have a pouch wrapped around the rollers.
carefully remove the pouch by cutting it into pieces with a sharp box cutter (be carefull not to cut the rollers) then pull out the pieces from the rollers then rethread the laminate rolls into the machine as you always have
2answers
Can you tell me how to thread a Graphic III laminator?
5-2 THREADING the LAMINATOR
1. Remove the supply roll mandrels and the feed tray. The supply roll mandrels are now ready to accept
loading of the film rolls, wound with the polyester (shiny) side out. When viewed from the front of the
machine, the core grippers on both the top and bottom supply roll mandrels should point toward the
heat shoes (and toward each other). The tension control knobs should be positioned on the right. Notice the
knobs are labeled "Top Right" and "Bottom Right". If you have rolls of film on which the material is wound
in the opposite direction (adhesive or dull side out) exchange the top and bottom supply roll mandrels so
the core gripper positions are reversed.
2. Slide a roll of film onto the top supply roll mandrel, turning the roll slightly to slide the gripper inside the
core. Center the roll. Make sure the dull side of the film is facing up and the shiny side is facing the
heat shoes during the threading. Scored marks on the supply roll mandrels provide a guide for proper
alignment of the two rolls of film to each other.
NOTE: The pointed metal pieces protruding from the body of the supply roll mandrels grip the cardboard core of the film supply roll to prevent slippage. When placing a roll of film on the mandrel, twist the film supply roll to
accommodate easier film loading.
3. With the roll aligned with the scored line on the right side of the mandrel, place it in the top bracket.
Place the left side of the shaft in its slot first then place the right side of the shaft in its slot, turning it as
needed. FOLLOW THE RECOMMENDED LOADING PROCEDURES CAREFULLY WHEN THREADING
FILM IN THE LAMINATOR. ACCURATE ALIGNMENT OF ROLLS WILL MINIMIZE WASTE AND HELP KEEP
THE LAMINATOR CLEAN.
4. While the machine is still cold, review the threading diagram. With the bottom roll of film centered on
the mandrel and the shiny side facing down, run the film under the bottom idler bar and pull towards
you.
5. Load and thread the top roll of film in the same manner as the bottom roll. Refer to the threading diagram. The
film should run under the silver stabilizer bar and over the front of the top heat shoe. Remember, the shiny
side of the film must always go against the shoe. The dull (adhesive) side must face away from the shoe.
Make sure the two rolls are aligned with each other before going to the next step.
6. Turn machine on and heat to the desired temperature.
7. With both rolls threaded and installed in their respective brackets, unwind enough film from the top roll
to reach the bottom of the bottom heat shoe. Next, unwind enough film from the bottom roll to reach the
top of the top heat shoe.
8. Now drape the film from the bottom roll against the film from the top roll on the top shoe. If the laminator is
hot, the exposed adhesive on the top web will hold the bottom web and make it easy to stick the two rolls
together. If you are threading the machine while it is cold, use tape to stick the bottom web against the top
web.
9. Tip the safety shield down into the laminating position. With the film draped over the two heat shoes, push
one edge of the threading card between the heat shoes so that the film is firmly positioned against the
laminating rollers. If a threading card is not available, any piece of card stock or poster board will work.
10. Make sure there is still enough slack in the web. Turn the drive switch to FORWARD, permitting the film and
feed board to pass through both sets of rubber rollers. Carefully monitor initial threading to be sure the web
reaches and passes through the pull (back) rollers. When the threading card has cleared the back of the
machine, move the drive switch to the center position (off). Whenever you want to remove the film and/or
laminated material from the back of the machine, use the zippy cutting tool provided with the laminator.
11. Slide the feed tray into position.
12. If the machine has the slitter option, make sure the slitters are disengaged (blades in the raise
position) and moved all the way to either side of the machine.
CAUTION: The laminator is designed to be run with the operator directly facing the
control panel and feed tray, not at an angle or from the side of the machine. For
operator safety, the safety shield must be in position over the upper heat shoe
when the machine is ON, or when the drive switch is in the forward position.
Top Gbc Office Equipment & Supplies Experts
ADMIN Andrew
ADMIN Andrew
bvmihai
Ngoro
Are you a Gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
