SOURCE: Camcorder Error
I had the same problem with my Viewcam Z. I couln't do anything with it anymore. Eventually got so annoyed that i actually called sharp to figure this thing out. From what technical support told me when you see E007 that means that there is some internal malfunction and the only way to repair the camera is to take it to a SHARP technition. so the question is would you pay alot of money to get this low end camera fixed?? i wouldn't..
SOURCE: Sharp + VL-Z7 + Software
Please go to: http://www.sharp-cart.com/ecom/accessories.htm?action=getSearchItems&ss_id=979&view=catalog/ss_items they have the CD-ROM for $ 11.00. Good luck
SOURCE: Replacement charger for Sharp Viewcam VL-Z3
As long as you can obtain a charger that is rated the same as the one for your camera it will not be a problem unless the original charger is a microprocessor controlled charger that has the ability to control and change the charging current as the battery charges.
A camera shop can check this out for you.
If it just a simple AC or DC charger, then you can simply use the connector from your original charger and join it either by soldering or with a screw terminal block(which you wrap in Insulating tape once fitted).
The main thing you need to be CERTAIN of is as to whether the original charger is an AC or a DC type.
This will be clearly indicated on the label on the charger.
Testimonial: "thank you for the answer. Bill"
SOURCE: what type of cassette do i need for a sharp VL-A10
You need to use a tape that says 8mm or Video8 only. I have provided a link to the type of tape that we would use.
http://www.amazon.com/Sony-MP-Video8-tape-120min/dp/B0009WUCG6/ref=sr_1_7?s=electronics&ie=UTF8&qid=1284056100&sr=1-7
There are tapes that say Hi8 and Dig8 on them. These tapes will not work properly in your camcorder because they are the wrong format. Your camcorder would probably chew the tape at some point if you tried to use this kind.
Hope this has helped.
www.austintelstarservices.com
