HOW TO CHANGE OIL PAN GASKET?
Changing your oil pan gasket is pretty easy. Just messy. What you first do, is of course make sure your can get to it safely by jacking it up. Now once you can get to it safely. Then next step in where the oil pan is, you will see a plug. Get your self a big pan for oil to drain into. Any auto store has them, and there cheep. Just them you need a pan to drain your oil. Now, put the pan on the ground under your car and right under the bolt that you will be unscrewing to drain the oil. Now that the pan is under that, use a socket or wrench and unscrew oil pan bolt, and drain all your oil into pan that is on ground under it. (note, best to let car cool a lot before doing this, so oil is cool and you do not burn yourself from any hot oil)
Ok, now that your oil is all drained out into pan, next step is to get a socket and socket driver and match up with all the bolts you see going around the oil pan. You will be unscrewing all of them around the whole oil pan. After all bolts are out ( store the bolts in like a little plastic cup to not loose them. Now, you will pull oil pan down and now is the fun part. Cleaning around where oil pan went, and on the oil pan itself you will be cleaning that up good around edges, What your doing is making sure the old gasket is off and if parts are stuck or broken, making sure that is all off. Once you get the oil pan edges and the part where it goes up is all clean, then you are going to out the new oil pan gasket on the oil pan itself, making sure it is on good, straight, level you know really make sure it is flush. Now, get a couple bolts ready and your socket ready, then your going to slowly put the oil pan back up, with of course the new gasket on it and hold it up in place and then put a bolt on at one end hand tight for now, then another other end hand tight. Sometimes if you have a small jack or few 2 by 4's to help hold it up in place helps. Once you get it up in place a couple bolts on, then start putting all the bolts back on, but only hand tight. Once all are on, now slowly with socket, start tightening them down in a circular motion. Meaning top left corner, bottom left corner, top left corner right, bottom left corner right. Like going around the world when tweaking them down, so not to warp one area before all are snug together. Now, clean up all your stuff. lower car back down.
DO NOT FORGET TO PUT PLUG BACK IN OIL PAN AND DON'T FORGET TO PUT OIL BACK IN CAR. You can use the same oil you took out and put back in to engine with a funnel. But I Always tell people, to dispose of old oil, and put new oil in. Check you dip stick to make sure at full line. Now start car, let run for about 15 minutes, look under for any leaks. IF none drive around for about 10 minutes, then turn off car, look underneath after about 30 minutes of car cooling to make sure no oil leak. If no leaks, congratulations you just properly changed A oil pan gasket. Thanks Mike
Sep 20, 2011 |
1995 Toyota Camry
