Dryer runs then shuts down wont start up for an hour:
Bad motor windings OR DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
SOURCE: Kenmore Elite Heavy Duty King Size Capacity Quiet Pack II Dryer shuts off
If the venting is clogged this will happen. And that is a good thing because it is a safety measure built in to prevent fires. There is a thermostat that can tell when your dryer is over-heating,(usually caused by clogged venting by lint) and this devise tells the heating element to turn off so as not to create a fire. Clean out venting, inspect thermostats and element, replace if neccesary. You may only have to clean out the venting.
SOURCE: Dryer making loud noise
the humming noise is most likely your motor. does it overheat or shut down on you? do you smell anykind of burning? Joe
SOURCE: Shutting off every 20 minutes
Your thremal fuse is getting hot. OR There are overloads attached to the element housing and one of them is getting hot and automatically resetting itself once it is cooled.
SOURCE: Maytag LDG 712 shuts off before clothes are dry.
First, The most common part would be the over limit safety, it will be mounted to the element housing. Second, there is a thermal fuse usually a small disk with a little fuse inside. You can find these (with your model no.) at www.Repairclinic.com .Good luck.
SOURCE: The dryer stops heating before the clothes are dry.
Maytag gas dryer MDG7600aww, (Model number corrected). Below is a link, courtesy of www.repairclinic.com showing the parts breakdown and disassembly procedures.
http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
This link shows the most likely cause of your issue.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg7600aww-%3d%3di3479&PartID=3479
This link shows the next likely cause of your issue. Remove the front panel and inspect the sensor bar which is located at the 4 o'clock level on the drum bulkhead, ( see the first link for location). Ascertain that 2 wires are connected to it and that black sensor bar is not cracked or broken.
This link will offer more assistance if the above 2 items check good.
http://www.repairclinic.com/0088_8_1.asp#Subtitle_2
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg7500aww-%3d%3di516693&PartID=516693
