Will new paint adhere to the existing paint or do I need to sand or prime?
Concrete floors and urethanes are a messy, messy business. You can really create a monster if you are not careful. Total removal of the substrate coating and a thorough cleansing with Muriatic Acid is most advised. To remove the ss coating, much easier than sanding, is to rent a "shot-blaster" from a local tool supply. Unlike sandblasting there is no powdery mess and the steel balls are recycled countless times. Once the concrete is clean and you have followed the mfgs directions with the muriatic acid and the floor is thoroughly dried, you can apply a 2-part catalyzed epoxy or urethane finish. These are readily available at a local paint store or a home improvement center such as Home Depot (they sell Rustoleums Garge Floor Coating). Hope it helps, CS
You did not provide info on the type of the paint and what surface it will be used on - there is difference between the floor, desk, wall and car body... all are flat surface but adhesion and work of the paint differs.
depending on the pre-existing paint, but you need always to "key-in" using 120 grit paper or 150 grit screen.
if paints are of same type, then paint in - if these are two different paints, you need to strip or isolate old paint, and then use new paint.
SOURCE: Need Painting Advice for Compound Troubled Areas
I don't think you can hurt it by sealing it from the outside. Your issue is the inside of the frame. The pillar is not airtight. Most of what you can use will smell for years if you spray WD 40 inside to displace moisture.
You might consider taking it to All-American car franchises or equivalent. They drill and plug body areas routinely to spray inside door panels,tailgates,etc. It would inhibite rust and unless you actually replace the metal when you want to paint the car, theres not much else you can hope to do. I live in the Michigan rustbelt area.
SOURCE: Painting my truck myself
you dont have to prime it but youll have to remove the factory clearcoat on the old paint its a good idea to sand it to remove all the clearcoat and contaminants i rinse the car and let it dry before i paint one
