Question about Brand Remote Start/keyless/car Alarm Very Sleek
How do i reset a 2003 1.4i golf factory fitted alarm
How can disconnect my immobilizer for citi golf 2008 model
If this is a factory fitted immobiliser then it would not be easy to disconnect!
Dec 06, 2014 | 2008 Volkswagen Golf 1.4
Golf 1 1.4i 2001 not starting because of factory
Hi. the factory alarm should not cause the car to not start. There will be an isuue with the key code or TCI ignition module. These need to be programmed after repairs so will need to go into a dealer.
Oct 14, 2014 | 2001 Volkswagen Golf
My 2007 golf immobiliser will not deactivate the alarm with the key fob, i have re coded it still nothing, removed the fuse and its fine. central locking also doesnt work. all factory fitted stuff.
its a 2007 model and as such can have the key fob reset with dealer diagnostic software ,wouldnt have thought removing a fuse would de-actrivate the factory immobilisor though
Apr 09, 2011 | Volkswagen Golf Cars & Trucks
Is it thatcham immobiliser in VW golf s v 1.6 2001 y reg
thatcham alarms were only fitted by dealers as aftermarket items for 10%off insurance premiums discount although this discount was stopped soon after they found out that thatcham alarms were causing lots of trouble with cars being immobilised for no reason and found to be unfixable by VW dealers.....you only have the factory standard alarm,unless YOU have a certificate showing that one was fitted.(insurance companies ask this question so that if you have an accident and you said yes,they can kick your claim into touch.....believe me any excuse.....)
Jan 07, 2011 | 2001 Volkswagen Golf
I have a vw golf gti mk3 2ltr 8v i have had a cliiford g5 fitted however since having it fitted the car keeps cutting out after about 10 minutes. i have had a diagnostics test done and has come up saying...
Unless you have a lot of VW specific diagnostic equipment - don't even try to do that. VW's are VERY FUSSY with their alarm systems and immobilizer; you even run into problems if you change the factory radio for an aftermarket, unless you buy the by-pass solenoid set up for your car with the radio.You might try to contact "Ron" at obd2tech.com and find out, if he can help you.
Dec 05, 2017 | 1995 Volkswagen Golf
Battery ran flat on my 'R' reg VW Golf gti while I was away in Australia. The alarm was disconnected a couple of years ago but now the immobiliser seems to have triggered as there is no spark or petrol...
sometimes it depends on the type of allarm, if it is factory fitted they are a nightmare to do as most of the wireing for the allarm is intergrated into the loom, where as if it is an after marked alarm ( one fitted later on ) it shouldnt be to bad but still a long and complicated job to find all the wires and reconnect the originals bypassing the immobiliser/alarm if you are a complete novice this should not be attempted as you could immobilise the car completely, best thing for you to do is get an auto electrician to have a look at it for you, sorry its not much help
Feb 15, 2010 | 1999 Volkswagen Golf
Security Alarm not working on VW Bora 2001
you can try to comand de doors puting the key in the door till all the windonwns are down than put than colse again maintainning the key in the close position
Oct 15, 2008 | 2001 Volkswagen Golf
Brand Remote Start/keyless/car Alarm Very Sleek Logo
56 people viewed this question
Top Spy Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
Kardoc
Mr.Mike
Are you a Spy Vehicle Part and Accessory Expert? Answer questions, earn points and help others
