I used to type in a number on google which used to pop up informing me about my toner levels. i got an update to an apple - and when i google and type in my specific code i end up in a different ITP site. Please assist me asap. many thanks! amorita
SOURCE: C6800 error code E000020-01a9
I don't have the manual for this machine, but if Canon is consistent then you problem is a fuser unit (the device that melts the toner to the paper) that is not heating up for some reason.
Possible causes are:
Blown fuser lamp
Defective thermistor
Defective AC Driver Board
SOURCE: Can no longer access Supply Levels info when
You might have to delete the printer tools software and the printer driver and reinstall. Also turn off the printer disconnect the usb and reconnect after you have reinstalled the printer drivers and tools. see if there is an updated driver on the manufacturers website.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
SOURCE: check toner level
RTFM
Read the operators manual
You should be able to replenish the toner yourself.
SOURCE: CHECKING THE INK LEVELS
just remove all the cartridges and you can see the level of ink .or you can go to printer service and maintenance option there also it show but that will not actual . So just remove and see the level..
Have a nice day and do not forget to rate please...!
