After replacing these three items black smoke exhaust still exists.
SOURCE: Husqvarna 350 running problem
Pull off the exhaust, does the piston look ok?
If scored thats not good.
If ok check fuel filter , pressure test lines or remove and check for cracks. Just a start but check easy stuff 1st or get back to me with more info, cheers
SOURCE: 455 Husqvarna chainsaw will not run
pull the muffler off and look for scoring on the piston,the 455 had a problem with running lean from factory and burned up a lot of pistons and cylinders
SOURCE: I have a husqvarna 51 which cannot be adjusted to
Check muffler & exhaust port for carbon up.
SOURCE: ignition coil
Here you go. If the price seems high there are likely several more to be found on this page. Good luck with it.
http://cgi.ebay.com/36-136-137-41-141-142-HUSQVARNA-SAW-IGNITION-COIL_W0QQitemZ270389321883QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3ef475a09b&_trksid=p3286.m20.l1116
SOURCE: 25 yr old Husqvarna 266. starts fine, lots power, but won't idle.
I think you have exceded our level of help. Please try here.
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
You might read this thread
http://www.arboristsite.com/showthread.php?t=110858&highlight=husky+266
I searched for "Husky 266" and got many positive hits. She is a respected machine.
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/9f5525102886abf488256b52001a33af?OpenDocument
HTH
Lou
