Saws Logo
A
Anonymous Posted on Sep 29, 2014
How do i know if i have the proper tension on the blade of my 14 inch bandsaw
Jack Faire
Level 2:
Sergeant:
  • Expert 468 Answers
  • Posted on Oct 01, 2014
Jack Faire
Expert
Level 2:
Sergeant:
Answers
468
Questions
0
Helped
113847
Points
736
There are all kinds of methods out there, such as plucking the blade like a guitar string until it produces a clear tone
of a specific musical pitch. The most accurate way is to check it with a tension meter.
Read this blog http://bandsawblog.com/blade-tension-2/
5 Related Answers
Anonymous
  • Posted on Jan 12, 2009
SOURCE: Grizzly bandsaw cannot fit blade
I lowered the spacer (on the threaded rod) and got enough drop in the upper wheel to fit the blade.
efs_perpends
efs_perpends
  • 1997 Answers
  • Posted on May 03, 2009
SOURCE: fitting new blade to a Naerok bandsaw BS-12
I'm not familiar with that brand, but please have a look at this post and see if it doesn't provide enough information to help you sort it out....click here
Also see:
http://www.fixya.com/troubleshoot/browse/band_saws
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Anonymous
  • 4090 Answers
  • Posted on Aug 29, 2009
SOURCE: 14'' Sears craftsman bandsaw blade slips off, not much power
It sounds to me like the blade has stretched which the do in changing temperatures.
Try replacing the blade before you give up altogether. i was having the same problem with a Ryobi Blade would come off whenever i tried to cut a pice of 3 ply. I eventually replaced the blade and all ny troubles evaporated.
Anonymous
  • Posted on Jan 21, 2010
SOURCE: hi i have a craftman bench 10 inch bandsaw that has blade drif
The problem could be one of two things. The tires could be worn or glazed with rosin. Try cleaning the tires with mineral spirits to remove the build-up. The other possibility is that the pulleys are out of alignment. To check this, put a straight edge across the face of the lower pulley and see if squares with the upper pulley, if it doesn't, loosen the set screw on the upper pulley and adjust accordingly
Anonymous
  • 4088 Answers
  • Posted on Jun 25, 2010
SOURCE: I am changing the saw blade on 12 inch Craftsman bandsaw
Go to: Searspartsdirect.com and enter the complete model number minus the decimal point. This will bring you a series of parts drawings and possibly an owner's manual. Generally, adjustment is provided for the upper wheel only--use hand power to check the tracking performance. Good luck!
Older sbw 3501 blade lenght
Bandsaw SBW3501B 14 inch cut 2553mm blade that is 100.51 inches blades are shipped coiled, WEAR GLOVES, blades are designed to cut !!! as you cut the last tie, throw the blade away from you as it will uncoil with some force. better for that force to hit the floor than your ear '-)
Jan 20, 2019 • Saws
I need to find the size and length of a powermatic bandsaw blade. Model PWBS-14
93.5 inches
Do you not have internet? I found the specs for your model instantly on Powermatic's web site. Don't be so lazy!!
Blade moves to the front and then pops off
1. Make sure you put the right tension. Check tension recommendations on your bandsaw/ manual.
Here's a good article about that. What is Bandsaw Blade Tensioning and Why is it Important
2. Adjust the blade tracking. I suggest you to read this blog for reference. Band Saw Tracking Procedures
How to install belt on rikon 10-325 bandsaw
For the high speed, (2950 ft/min), the belt should be installed on the rear pulley of both the motor and the wheel. For the low speed( 1445 ft/min), the belt should be installed on the front pulley of both the motor and wheel. To properly adjust the belt tension, turn hand wheel until there is 1/2" deflection in the "multi-vee" belt. Check this link to see the manual. http://www.highlandwoodworking.com/library/manuals/10325_manual.pdf
By the way, where do you get your band saw blades? I got mine from sawblade.com and I happy with them.
Setting the proper tension on a Craftsman 10" band saw model 124.214000.
Hope this blog will help you http://bandsawblog.com/blade-tension/ .
What's your band saw blade? I am using Haltbar blades and never got problems tensioning.
1helpful
3answers
I'm looking for replacement bandsaw blades for a McGraw-Edison 10" Bandsaw, M/N - T6760. Any Ideas?
I have 11[6 tooth scrolling blades] & 3[3/8" 14 tooth general purpose metal cutting blades.T8380-16 & T8382-16 for McGraw Edison 10" bandsaw. blades are 57" been hanging in my garage for past 25 yrs lol. would like to sell to best offer. contact me at [email protected]
Feb 24, 2011 • Saws
3helpful
I cannot get the blade to track correctly on my JET 12" band saw. What could be wrong? I have done exactly what the manual says to do. I am not sure the square box on the outside is fitting. The little arm...
i love bandsaws, they are one of best and most universal woodworking machines, used as well in food and metal industries.
now, what you should know about bandsaw that it have several points of regulations and all of them must be adjusted correctly. basic "anatomy" of bandsaw is that it have body, in it there is driving wheel (bottom) and tension wheel (top), both of these are protected by rubber "tyre" usually crowned, that allow for bette adjustment and protect teeth on the band.
start with tension, open covers, retract top (above the table) and bottom (below the table) guides so blade is not touching the rear bearing or side slides.
1. rotate top wheel and see where blade is wandering, regulate tension and tilt on the wheel till band position itself on the centre of the top wheel and cuttin edge is off the wheel or rubber and do not touch the wheel or raiser.
2. cut strip of paper and slide top guide towards the blade till bearing touch blade through the paper (paper thickness is about correct distance of bearing to the blade), allowing paper to be slided out without tension. lock it in.
3. insert paper on internal side of the blade and slide internal slide guide block till you can only pull the paper out, lock the slider.
4. repeat previous operation on external guide block and after you slide paper out, lock it in position.
5. manually rotate the tension wheel, should operate freely, without wandering
6. repeat step 2 to 5 on the bottom guide
7. close the covers
8. adjust hight of the guide suitable to cut , allowing about 2 finger breaths above the cut piece.
9. switch on the bandsaw and switch off, after it stop, check for tension, switch on and make test cut.
this general rule applies to all bandsaw, regardless of brand, make, vintage. do remember that this is not a toy, it will cut through, wood, metal and your fingers...
do remember, that these operations must be performed every time when you change the blade, to not forget to use bit of silicone or teflon spray if you cut very sappy or green wood, do not press and force, use protection screen and googles, you have only two eyes and there are no spares...
Aug 29, 2009 • Saws
Jan 11, 2009 • Saws
Top Saws Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Saw Expert? Answer questions, earn points and help others
